329
Topics138,075
Posts1,080,454
Members14,973
Most Online678 Dec 8th, 2019
Re: 2.3L Stroker info post
[Re: DEFBOY35]
#938227
10/02/09 05:37 AM
The front differential and the transfer case is something to worry about, though. They are both the weak points in our drive train, so I've been told.
[Re: SKC]
#938228
10/09/09 06:30 AM
coming to the stroker thing again, look this http://carinfo.autold.com/car-kia_potentia-22.htmldont stay on the hp look at the diameter...
[Re: k120189]
#938229
10/20/09 02:38 PM
Here's what I found. 240 RWHP Stroked FE3 http://www.solomiata.com/FE3.html
[Re: 2002_Sporty]
#938230
10/20/09 02:56 PM
I have read this so many times The thing with this mod is that they were aiming for turbo-ing the engine so thei had special needs conserning straingth. What I think we are looking for is a simple mild improuvment with aw many stock and easy to find parts that would give low torque reliably and not having to fix things every now and then
That is why the b2200 crank and rods only, if they fitted would give a estimated 2200-2300cc with all the rest possibly stock maybe a litle bit of fuel presure more to compensate for the sligtly biger cylinders.
Why wont I try it you may ask and its pretty reasonable. the answer is that I have a perfectly running engine and no spare money to dissasemble it just for the fun of it. If I had a reason like worn piston rings an a smoking engine in need for a re-build, I surely would give it a try, since it would be already in pieces
[Re: fokion]
#938231
10/23/09 04:29 AM
how much would it cost to do a full rebuild with the stroker parts? (i have a bad rod knock, perfect candidate) either that or engine swap... i think swapping ina junkyard motor would be the cheapest..
[Re: sportagebandit]
#938232
03/18/14 07:25 PM
well after about 1400 years. im back been through a couple of vehicles and im picking up another sportage soon..anyone still alive here? im going to pick this back up and continue my plans to build the 2.3L stroker.
[Re: k120189]
#938233
06/02/14 11:38 AM
Came across a guy on another Kia forum that has built a 2.3 stroker in his Sporty in Australia.
I have asked for more info <img src="/forums/images/graemlins/evil.gif" alt="" />.
Will keep you up to date <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: 4runnernomore]
#938234
06/27/14 10:21 AM
oooh do tell <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Davey]
#938235
06/27/14 11:51 PM
Hi Davey,
You might know the car or person? It is a red sporty in WA. Goes by DPK on the Kia forum. Have sent him a couple of PM's . No reply yet.
[Re: 4runnernomore]
#938236
07/08/14 01:11 AM
Hi all,
I am still waiting on a detailed reply from Dave (DPK) from the Kia forum however I did get a snippet from him about his 2.3 stroker motor which includes briefly R2 crank diesel , std rods ;manufactured pistons.
Once I find out more I will post up for all to see <img src="/forums/images/graemlins/patriot.gif" alt="" />
