66
guests, and 4
Re: 2.3L Stroker info post
[Re: 4runnernomore]
#938237
07/08/14 01:51 PM
I know that other 2.3 build use an F2T crank from a Ford Probe turbo, and pistons from a mitsubishi 4G63.
I forget what they use for rods in those, but I know the MX6 guys are putting nearly 200whp out there...
[Re: DRX350]
#938238
07/15/14 01:31 PM
Hello forum, I have had some discussion with 4runnernomore on the the kia site regarding the 2.3 litre engine.Or more importantly the one I have built as Chris has already mentioned I have used the the r2 diesel crank. I used that because its the strongest being forged steel as opposed to the cast iron variants of the same stroke.The other benefits were the timing dowel is in the same position as the sportage crank and has the same bolt pattern as the sporty. The timing gear has to be removed from the diesel crank I used a spark eroder(edm machine) to split the shrunk on gear.I had read in a different post that a careful bit of disc grinding does the same trick.The diameter that the gear sat then was milled down to make two drive flats for the oil pump.The only real drama was spark eroding oil holes though the bearing journals as the the r2 crank has angular oil holes from main crank journals feeding the nearest cylinder journal bearing.I used standard sporty plan bearings as opposed to grooved bearings that the r2 crank used . I,ll fill out a few details on next stages tomorrow night. regards Dave
[Re: classicracer]
#938239
07/16/14 03:11 AM
Looking forward to all your information as I have plans to build one. I have purchased a 2.2 gas crank so I will need to deal with the flywheel hole issue. What rods and pistons did you use? Did you use any special head gasket to allow for the larger bore? Pictures would be appreciated!!! Thanks for joining and sharing!
Everet
[Re: classicracer]
#938240
07/16/14 11:32 AM
The timing gear has to be removed from the diesel crank I used a spark eroder(edm machine) to split the shrunk on gear.I had read in a different post that a careful bit of disc grinding does the same trick.The diameter that the gear sat then was milled down to make two drive flats for the oil pump.The only real drama was spark eroding oil holes though the bearing journals as the the r2 crank has angular oil holes from main crank journals feeding the nearest cylinder journal bearing.I used standard sporty plan bearings as opposed to grooved bearings that the r2 crank used . I,ll fill out a few details on next stages tomorrow night. regards Dave Hi Dave, glad to see you on the forum. I am having issues with access again to the Kia forum. Cheers, Chris
[Re: Everet]
#938241
11/12/14 01:45 AM
subscribed... thanks guys!
