the cold start shuffle got me
by keetz - 04/12/22 01:32 AM
0 registered members (), 67 guests, and 2 spiders.
Topics138,274
Posts1,081,733
Rating: 1
Page 9 of 9 1 2 3 4 5 6 7 8 9
Re: 2.3L Stroker info post [Re: 4runnernomore] #938237 07/08/14 01:51 PM
DRX350 Offline
I know that other 2.3 build use an F2T crank from a Ford Probe turbo, and pistons from a mitsubishi 4G63.
I forget what they use for rods in those, but I know the MX6 guys are putting nearly 200whp out there...
Re: 2.3L Stroker info post [Re: DRX350] #938238 07/15/14 01:31 PM
C
classicracer Offline
Hello forum,
I have had some discussion with 4runnernomore on the the kia site regarding the 2.3 litre engine.Or more importantly the one I have built as Chris has already mentioned I have used the the r2 diesel crank.
I used that because its the strongest being forged steel as opposed to the cast iron variants of the same stroke.The other benefits were the timing dowel is in the same position as the sportage crank and has the same bolt pattern as the sporty.
The timing gear has to be removed from the diesel crank I used a spark eroder(edm machine) to split the shrunk on gear.I had read in a different post that a careful bit of disc grinding does the same trick.The diameter that the gear sat then was milled down to make two drive flats for the oil pump.The only real drama was spark eroding oil holes though the bearing journals as the the r2 crank has angular oil holes from main crank journals feeding the nearest cylinder journal bearing.I used standard sporty plan bearings as opposed to grooved bearings that the r2 crank used .
I,ll fill out a few details on next stages tomorrow night.
regards Dave
Re: 2.3L Stroker info post [Re: classicracer] #938239 07/16/14 03:11 AM
Looking forward to all your information as I have plans to build one. I have purchased a 2.2 gas crank so I will need to deal with the flywheel hole issue.
What rods and pistons did you use?
Did you use any special head gasket to allow for the larger bore?
Pictures would be appreciated!!!
Thanks for joining and sharing!
Everet
Re: 2.3L Stroker info post [Re: classicracer] #938240 07/16/14 11:32 AM
4
4runnernomore Offline
Hello forum,
regards Dave
Hi Dave,
glad to see you on the forum.
I am having issues with access again to the Kia forum.
Cheers, Chris
Re: 2.3L Stroker info post [Re: Everet] #938241 11/12/14 01:45 AM
tspot Offline
subscribed... thanks guys!
PHP: 7.4.29 Page Time: 0.033s Queries: 16 (0.015s) Memory: 2.9034 MB (Peak: 3.1934 MB) Data Comp: Off Server Time: 2022-05-29 02:30:29 UTC
