114
Topics138,177
Posts1,081,002
LandCruiser brakes are easy
#939048
04/06/09 04:20 AM
Pull the tire, remove retaining clip, pull two pins, remove pads, slide in new pads, replace pins and clip. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Besides removing the tire the only tool you need is a big screwdriver-prybar to push the calipers back.
Yes, I used the anti-squeak stuff <img src="/forums/images/graemlins/patriot.gif" alt="" />
98 Montero with cold weather package 96 Toyota Land Cruiser, fully locked Mall Machine :-)
Re: LandCruiser brakes are easy
[Re: LRJ4x4]
#939049
04/06/09 11:43 AM
Former Admin
I used 100-Series pads on the front of mine w/ new rotors when I did the front axle service recently - whoa! Very substantial difference!
[Re: little_joe]
#939050
04/06/09 12:49 PM
I used 100-Series pads on the front of mine w/ new rotors when I did the front axle service recently - whoa! Very substantial difference! 100 series pads are something I haven't tried yet. When I did mine I regrettably went with 80 series pads, but I did notice a huge difference between the OEM pads and the not quite worn out aftermarket pads the PO put on there. Either of you guys experiencing the sluggish 80 series brake pedal?
[Re: LRJ4x4]
#939051
04/06/09 05:29 PM
Yup, same setup on 96+ 4Runners and Tacomas, and all Tundras. Sequoias too I think.
[Re: LRJ4x4]
#939052
04/06/09 05:49 PM
Yes, I used the anti-squeak stuff <img src="/forums/images/graemlins/patriot.gif" alt="" /> That does sound easy although I'm not complaining since the Mitsu's aren't exactly hard either. Need a socket wrench (14mm?) and a big c-clamp (to compress piston) for my gen I. Hope the Gen II's the same. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#939053
04/06/09 06:12 PM
14mm is correct. Gen2 is just as easy as the front of the gen1. I just put pads on my 95 rear axle on my gen1 yesterday.
[Re: sparkem]
#939054
04/06/09 07:48 PM
14mm is correct. Gen2 is just as easy as the front of the gen1. I just put pads on my 95 rear axle on my gen1 yesterday. Good to know. Hey Les, how exactly does this retainer system work on the LC brakes? That's a 100 not an 80 LC right?
[Re: off-roader]
#939055
04/06/09 09:03 PM
We usta call those Ate' pattern calipers, usually with two pistons. My opels had those. Two pins with a spring clip hooked on them than hold the pads in the caliper. The caliper did not float like a mitsu. IIRC, we called the mitsu type "girlings". Both are brand names, like brembo.
[Re: off-roader]
#939056
04/06/09 09:35 PM
14mm is correct. Gen2 is just as easy as the front of the gen1. I just put pads on my 95 rear axle on my gen1 yesterday. Good to know. Hey Les, how exactly does this retainer system work on the LC brakes? That's a 100 not an 80 LC right? Les has an 80series just like Brian, which you can put 100 pads in.
[Re: sparkem]
#939057
04/07/09 02:43 AM
When you say 100 series what do you mean? I have a landcruiser and am curious?
1990 Black Monty LS Over 300K' 1993 Isuzu Rodeo LS 4x4 46k (yes only 46K!)1989 Honda Transalp 600 Africa twin,
