How are vaccinations going in Europe?
by gmong - 02/26/21 04:07 AM
Replacement MAF unit .. Gen1
Gen1 cigarette lighter port.
GEN I Auto hubs
by polar - 02/16/21 03:03 AM
GEN I Auto hubs
0 registered members (), 107 guests, and 6 spiders.
Topics138,177
Posts1,081,002
Loud screech while in 4x4 #943536 05/04/09 04:36 AM
ChrisB Offline OP
was out 4 wheeling today and the front end started to screech pritty loud.I thaught it was the breakes.When i got home i layed under the car while it was out of 4x4.Stun the front dive shaft bye hand and only the driver side cv axel would spin.The passenger is kinda hard to turn bye hand. Whats the fix, sounds like a wheel bearing? or maybe just mud in it?
01 Kia sportage,Removed front bumper,Warn manual hubs,
Make it Break it
Re: Loud screech while in 4x4 [Re: ChrisB] #943537 05/04/09 04:55 AM
Iron Offline
Take the hubs off, re-pack the bearings and hubs with grease, clean out any and all old grease and crap thats in there. Chances are you just got water and mud into the hubs or bearings! You should re-pack the bearings everytime you do a water crossing or wheel in mud, also check the rear drums to make sure you don't get any mud build up in them!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: Loud screech while in 4x4 [Re: Iron] #943538 05/04/09 05:03 AM
ChrisB Offline OP
I just greesed the hubs and rtv'd them when i put them on.How do i pull the hubs apart and greese them and the bearings?
Make it Break it
Re: Loud screech while in 4x4 [Re: ChrisB] #943539 05/06/09 02:12 PM
ChrisB Offline OP
Any help??
Make it Break it
Re: Loud screech while in 4x4 [Re: ChrisB] #943540 05/06/09 02:58 PM
DamKia Offline
Kia Moderator
I'm guessing you have mud behind the brake pads, pull it all down and give it a good clean. If that doesn't fix it then attack the bearings (simple/cheap stuff first). Could also be a seized brake piston from the mud, so try to ascertain if there is any movement of the piston with brake application (with brake pads in place and on the disc.
Any chance mud could have gotten into the wheel bearings through a dislodged old vacuum line on the back of the knuckle???
People do the right thing and replace the hubs with the manuals and dont bother to pull the vacuum lines off the back and plug the hole. Hoses rot/get caught, water + dirt + mud = noisy bearings.
Glue a bolt into the end of the nipple that takes the vac hose on the knuckle. Pull all the associated bits away and do a similar theing to the vac supply line from the manifold.
The hub itself (the bit you buy from Warn) will not make any noise on its own if you can fully rotate the dial to the locked/unlocked position.
Re: Loud screech while in 4x4 [Re: ChrisB] #943541 05/06/09 11:27 PM
Iron Offline
Same way you put them on, but backwards! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
08' Jeep Wrangler
58' Triumph TR-3A
Re: Loud screech while in 4x4 [Re: Iron] #943542 05/07/09 04:42 AM
ChrisB Offline OP
oh i thought you ment to take the hub off the car then pull the insides out of it.
Make it Break it
Re: Loud screech while in 4x4 [Re: ChrisB] #943543 05/07/09 04:48 AM
Iron Offline
It's fairly fast and simple, and something you should do when ever you do a water crossing or play in the mud! You'll most likely find some water and dirt in the hubs, take a look at the colour grease your putting in and compare it to that your pulling out and you'll see why! I have a tub of grease in my trail bag just incase!
08' Jeep Wrangler
58' Triumph TR-3A
Re: Loud screech while in 4x4 [Re: Iron] #943544 05/07/09 04:50 AM
ChrisB Offline OP
Is it a pita to re grease the wheel bearings?
Make it Break it
PHP: 7.2.34 Page Time: 0.029s Queries: 15 (0.008s) Memory: 2.8639 MB (Peak: 3.1635 MB) Data Comp: Off Server Time: 2021-02-26 16:52:16 UTC
