97
Posts1,080,940
New kind of lift
#947137
05/28/09 09:34 PM
so everyone talks about dropping the front diff...which doesnt seem too hard by why stop there for only an inch of lift why not drop the whole front suspension down?
im starting to design a front lift that will be in th 6-8inch range making 33-35's possible.
so far the things i foresee needing changing are: brake lines swaybar maybe the drive shaft?
so help me out here i'll gladly share any blueprints i come up with and how would i go about matching that in the rear?
my thoughts are if tj 106 lift four inch then tj 3inch or so lift coils will put me where i want to be.
to me this all seems simple but i dont see it done much is there something im missing?
Re: New kind of lift
[Re: k120189]
#947138
05/28/09 11:36 PM
I have been going over something like that in my head for years and even tried to draw up some plans. I even have dif drop down brackets made. There is one part I have been having problems with, the upper control arms. I think you could make a custom pair to fit in the stock mounts but drop down mounts would be hard because the mounts on the frame are on a slight angle. Please post what you come up with, I realy want 35s on my kia. I have been thinking hard on a sas while the engine is out but I need to go wheelin soon or I'll go crazy, the Probe is fast fun but I would rather be wheelin.
[Re: DennisThompson]
#947139
05/29/09 02:23 AM
have had ample oportunity the last couple weeks to look at how it could be done and was thinking of making up some plans for this style of lift.
i was thinking of designing it to work with the rocksport or spacer lift and use the extended forks from korea, if one could get them, or have some custom machined out of billet or something.
but i was also thinking that the control arms would be new wide long travel units combined with the extended lift. so custom cvs would need to be sourced etc. drop the dif down about 2 or 3 ".
but i would not have been able to test it all in my truck anymore, so perhaps if i do get a second sporty down the road it may happen.
the rear at that height you would be looking probably new longer control arms, and shocks and the springs, and the tj lift coils is what i was toying with. might be excessively stiff though for the sporty.
how does the stock tj coils ride?
[Re: DEFBOY35]
#947140
05/29/09 02:42 AM
my tj coils are nothing to complain about they ride nice flex good..it feels like a truck now vs something that wanted to be.i had the same idea about the extended forks too. dennis i see what u mean im sure i can find a way around upper arm problem solved...problem two... STEERING! the steering rods pivot at a point near the lower arm as you can see..if we dropped the arm 8in we would have to drop the rod too..or else forget bump steer it'll be bump toe hit a bump and u'll toe out major.. ideas? i'll post some of my sketches up ina bit..if you can even take anything from them clickable thumbnails ![[Linked Image]](http://img.photobucket.com/albums/v735/k120189/th_SCAN0002.jpg) ![[Linked Image]](http://img.photobucket.com/albums/v735/k120189/th_SCAN0003.jpg)
[Re: k120189]
#947141
05/29/09 04:53 AM
take a look at the Calmini kit for the Nissan Navara.. it will give you ideas for many things specialy the upper thing.
[Re: fokion]
#947142
05/29/09 01:57 PM
i got that figured out..two ways will post scans later.
dennis can u post pictures of your diff drop brackets?
deffboy is your sporty still apart? can u measure from the hole in the upper arm mount straight down to the hole in the lower arm mount. i found a was to make this work but that number would almost be the amount of lift
[Re: k120189]
#947143
05/30/09 12:50 AM
the sport is still apart, but there is no possible way for me to take that measurement anymore at this point!
i was thinking before, that instead of dropping the uppers down, i would have machined a new upper balljoint spacer that would bolt into the top of the knuckle and correct the geometry.
[Re: DEFBOY35]
#947144
05/30/09 03:47 AM
started the sas did ya?
i'll post a screen shot of my idea in cad in a bit
[Re: DEFBOY35]
#947145
05/30/09 06:25 AM
i was thinking before, that instead of dropping the uppers down, i would have machined a new upper balljoint spacer that would bolt into the top of the knuckle and correct the geometry. me too
[Re: k120189]
#947146
05/30/09 07:26 AM
<img src="/forums/images/graemlins/smile.gif" alt="" />
