114
Topics138,177
Posts1,081,002
Re: 88 truck on 85 axles and broke!
[Re: TayJ]
#950253
06/22/09 03:55 AM
Here's a link with a few pics to give you an idea of what's lacking under the rear end TayJ. Modded '82
[Re: kewlynx]
#950254
06/23/09 04:05 AM
[Re: BROWNBAGG]
#950255
06/23/09 05:12 AM
Thanks all, this is the first leave sprung crawler I have delt with. Blocks will be gone, going with better leaves, probably the trail gear ones and going to make an anti-wrap bar.
What else do I need to do to make this thing ready to rock and in a way that we won't need to worry about it?
Jeep Jus' sayin'
88 on 1 tons!
[Re: TayJ]
#950256
06/28/09 09:26 PM
So the decision has been made. Going to keep running the 40 inch Iroks but going to scrap the toy axles and swap in a Dana 60 front and 14 bolt full float rear! More than likely it will still be sitting on leafs front and rear but the idea of a rear four link is being tossed around.
Jeep Jus' sayin'
Re: 88 on 1 tons!
[Re: TayJ]
#950257
06/28/09 09:30 PM
So we got it sitting on the rear axle again with the block under the spring so it will be sitting more level so we can get started. While we are waiting on the axles and new wheels we are going to cut off the rock sliders, remove the body lift and put the sliders back on. ![[Linked Image]](http://i272.photobucket.com/albums/jj192/yyaatt/Tays%20Projects/PICT0137.jpg)
Jeep Jus' sayin'
Re: 88 on 1 tons!
[Re: TayJ]
#950258
06/29/09 02:33 PM
Your front spring perches look kinda scary in those pics. I have heard of sas spring perches that weren't reinforced enough breaking loose.
93 4runner V6, 4.88's, 31" mt's with more to come. 03 Tundra V8 on 265's
Re: 88 on 1 tons!
[Re: Billydkid]
#950259
06/30/09 06:18 AM
Your front spring perches look kinda scary in those pics. I have heard of sas spring perches that weren't reinforced enough breaking loose. Swapping in D60 front so we will have a chance to make real strong perches! Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jeep Jus' sayin'
Re: 88 on 1 tons!
[Re: TayJ]
#950260
06/30/09 06:43 AM
Anything stronger than what's under there will be a good thing. <img src="/forums/images/graemlins/rodent.gif" alt="" />
BTW, what's that little pickup I see a corner of to the right? <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: 88 on 1 tons!
[Re: kewlynx]
#950261
06/30/09 02:01 PM
Blocks had nothing to do witht he problem - they're mounted on top of the springs as a spacer.
Those leafs simply have no ability to prevent axle wrap... three thin leafs w/ no overload - they never had a chance.
An trac bar is the best bet if you need to keep the thin pack. Budbuilt has a bolt on unit.
Brian K. Gallus I have nothing important to say.
Re: 88 on 1 tons!
[Re: bkg]
#950262
06/30/09 02:28 PM
Blocks had nothing to do witht he problem - they're mounted on top of the springs as a spacer. I'm guessing since the rear is much lower than the front in the first set of picks, they just threw it back together with the blocks above the springs instead of the blocks under spring.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors 89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels 99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
