'87 Montero clear coat flaking
by rxinhed. 07/21/18 06:02 PM
Battery light - what's it telling me?
by rxinhed. 07/21/18 05:53 PM
by rascott. 07/19/18 03:18 AM
Echo
by rxinhed. 07/11/18 02:22 AM
1989 GEN 1 3.0L Oil Pressure
by DRLExpress. 07/05/18 08:41 PM
GEN1 LWB Radio reception
by chadzeilenga. 07/04/18 05:46 AM
Need Help - SOHC Valve Adjuster Replace
by tdf46. 07/03/18 01:38 PM
by GrantCee. 07/14/18 10:27 PM
by GrantCee. 07/12/18 12:32 AM
by tdf46. 07/03/18 02:02 AM
Bouncy seat
by montero1970. 07/01/18 06:57 PM
The slow rebuild thread
by DRTDEVL. 06/30/18 03:28 PM
Scratch my last post... wow!
by DRTDEVL. 06/28/18 02:08 PM
My '88
4x4Wire YJ
Topics137,890
Posts1,079,532
Members14,783
Crankshaft Holder #951122
06/26/09 09:49 AM
06/26/09 09:49 AM
R
rognik39  Offline OP
australia
Rodeo V6 3.2l
Hi All
Can anyone advise of an alternate tool or method to remove a crankshaft pulley.
GM instructions are to use a crankshaft holder 5-8840-0133-0 which is a Kent Moore Pulley Holder J-8614-01
Need info for the morning
Thanks
Re: Crankshaft Holder [Re: rognik39] #951123
06/26/09 10:05 AM
06/26/09 10:05 AM
boritz  Offline
Victoria, Australia
On my 1997 Isuzu 3.2V6 there are 2 threaded holes near the outer rim of the pulley. I made-up a steel bar to lever against bolts screwed into those. Links to pics below.
Some folks use the starter to 'crack' the retaining bolt loose.
If you have a manual trans you may also find that it will hold the crank for you with the park-brake on.
Here's a link someone hosted to download my timing-belt DIY PDF for the 3.2V6 SOHC
http://www.datazap.net/sites/Australia4W...r_Pump_rev2.pdf
Original post was here: http://forum.australia4wd.com/index.php?showtopic=7463
For folks with DOHC motors - very useful info here: http://forum.planetisuzoo.com/viewtopic.php?t=16972
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
Re: Crankshaft Holder [Re: boritz] #951124
06/27/09 12:48 AM
06/27/09 12:48 AM
R
rognik39  Offline OP
australia
Hi
Can anyone confirm that the cranshaft bolt is right or left hand thread as I am assuming a right hand thread and it dont budge!
thanks
Re: Crankshaft Holder [Re: rognik39] #951125
06/27/09 02:03 AM
06/27/09 02:03 AM
boritz  Offline
Victoria, Australia
Definately right-hand thread.
Righty-tighty, lefty-loosey!
24mm (15/16" AF)
123 lb-ft.
Re: Crankshaft Holder [Re: rognik39] #951126
06/27/09 02:23 AM
06/27/09 02:23 AM
bamashooter  Offline
Alabama USA
If you have access to and room for an impact wrench, it should remove the crank bolt with ease. I fought and fought with mine weeks ago. My radiator, fan, etc were removed. I dropped the gun down there and that bolt spun out so easily I thought something had gone awry. No problems; just a clean, easy removal. I've known folks who used the "bump the starter" method with great success also.
Re: Crankshaft Holder [Re: rognik39] #951127
07/01/09 01:06 AM
07/01/09 01:06 AM
C
Chad Hunter  Offline
Highland,UT,USA
Round up a 1/2" impact gun, it makes the job so very much more enjoyable. I like to pull the rad, just to get it out of the way, a 1/2" impact gun and socket will just fit in the space. Its right hand thread and it will be an absolute bear to brake free.
1987 trooper LS.'94 3.2, SAS,35's , lots of dents and rust. Now, improved, with more dents.
1995 trooper LS. Wife won't let me improve this one.
1996 trooper. I'll need something to modify when the '87 finally rusts away.
Re: Crankshaft Holder [Re: rognik39] #951128
07/01/09 09:18 AM
07/01/09 09:18 AM
AIR AMIGO  Offline
Sunnyside, WA
I just rebuilt the top of my motor the other day, and I have two pieces of advice:
1) Buy one of those heavy duty strap wrenches. Slip the loop over the crankshaft pulley, and have 1 person hold it tight with the use of a cheater bar. I used a hi-lift cheater bar, which I sliped over the end of the heavy duty strap wrench. It worked like a charm!
2) Go to Autozone and buy a Chrylser Harmonic Balancer Puller. This awesome tool allows you to grip onto the belt riding surface of the harmonic balancer, to pull the harmonic balancer off. This eliminates the need to use the treaded holes for pulling the balancer off. It cost me $70, but it was the quickest harmonic balancer removal job I'v ever done.
Good Luck!
Keith J.
www.myspace.com/keith771
AIR AMIGO!
AirAmigo@hotmail.com
Pacific NW Isuzu Off-Roaders
Timber Tamers #172
Sunnyside Fire Department IAFF Local 3542
Page Time: 0.010s Queries: 15 (0.004s) Memory: 1.0196 MB (Peak: 1.1242 MB) Zlib disabled. Server Time: 2018-07-22 10:39:22 UTC
