by polar - 01/14/21 08:42 PM
by polar - 01/14/21 08:40 PM
torsion bar question
Vet over his Head
by tcb762 - 01/12/21 11:02 PM
by code33 - 01/03/21 03:52 AM
Vet over his Head
0 registered members (), 119 guests, and 6 spiders.
Posts1,080,940
starter replacement #956580 08/01/09 02:14 AM
londart Offline OP
does anyone have some ideas on the fastest way to change out the starter,mines been makin some noise for awhile and is now toast so i have to change it this weekend. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Lonnie
Auto Parts Professional
Re: starter replacement [Re: londart] #956581 08/01/09 01:38 PM
budicexxx Offline
i'll let you know this afternoon as i am changing mine today. Not sure if its the same as a 2001 but ill let you know. Doesn't look too complicated. Just know 2 bolts you have to get from underneath.
Re: starter replacement [Re: budicexxx] #956582 08/01/09 03:16 PM
londart Offline OP
thatd be great,thanx...i planned on doin mine this morn but my boss called me last night sick and the only other 2 that can open the store are out of town so that leaves me...yay, another short weekend
Lonnie
Re: starter replacement [Re: londart] #956583 08/01/09 03:50 PM
k120189 Offline
i've done mine two ways. pulling the intake and going from the top was easier. a lot easier. went thru the bottom it was hell
Re: starter replacement [Re: k120189] #956584 08/01/09 07:16 PM
budicexxx Offline
ok i went from the bottom....first off make sure the engine is cooled down....wow it stays hot for quite some time. There is only one botl that is hard to get at..Had to use a knuckle, 14mm socket and two long extensions. that rested next to the front drive shaft. Once i cracked that one loose i used a flex extension. The other two are easy access. Myself i had to removed the oil filter to get the starter out. To reasemble seemed alot easier. But MUST and i mean Must have patience....lol
Good Luck
Re: starter replacement [Re: budicexxx] #956585 08/01/09 07:32 PM
How may cocktails? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: starter replacement [Re: Everet] #956586 08/01/09 10:20 PM
budicexxx Offline
Well i thought hard about it but figured i would never finish today....hehe
Re: starter replacement [Re: budicexxx] #956587 03/14/10 11:59 PM
Would like to thank everyone for this info.
Here's what I found out while I got to change mine on the 2000 2dr Automatic.
You can do EVERYTHING from under the car except unhook the NEGATIVE and POSITIVE Battery Cables. (do negative FIRST)<img src="/forums/images/graemlins/shame.gif" alt="" />
budicexxx, the idea about using every extension in the neighborhood to get at the most difficult bolt was MOST helpful <img src="/forums/images/graemlins/kewl.gif" alt="" />. One thing: If at all possible, don't remove the bolt from the bellhousing. That way you don't have to try and find an easy way to put it back in to start it <img src="/forums/images/graemlins/frown.gif" alt="" /> .
Unplug the wire with the female spade lug to the solenoid and removed the 3 bolts. when the starter drops loose, rotate it around and remove the 12mm nut on the Positive wire from the battery to the solenoid.
Going back in, put the main positive wire on the solenoid, tighten it down and then position the starter back in the bellhousing.
Start the easier bolts into the threaded holes but leave them loose.
Now, use your 50 foot long gang of extensions and start the most difficult bolt and while your turning the bolt, you can move the starter slightly to align it with the bolt.
Tighten everything up, not forgetting that the bolt closest to you while your under the car has the ground cable attached to it!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> (I wonder why that was written...<img src="/forums/images/graemlins/angry.gif" alt="" /> )
Then hook up the wire with the female spade connection to the terminal on the solenoid.
Hook up the Main Positive cable to the battery, THEN hook up the negative cable and jump in and start it!!!
It should take about 3 cocktails not counting the time it takes to borrow every extension in the neighborhood.<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Thanks again for this forum saving the day...all you have to do is search a little first and most answers are already posted.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: starter replacement [Re: Everet] #956588 03/15/10 01:18 AM
bombardj1 Offline
when you borrow those extension did you make a list and mark then 1, 2, 3. and so on, so they back to there homes <img src="/forums/images/graemlins/kewl.gif" alt="" /> I have lost a lot of tools with my stepkids <img src="/forums/images/graemlins/angry.gif" alt="" />
Glad you got it in and out <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: starter replacement [Re: bombardj1] #956589 03/15/10 02:39 AM
DennisThompson Offline
One thing I found that makes it easier is to remove the brace that goes from the bottom of the intake to the engine block just behind the motor mount. I have not tried it with the oil filter removed, I might have to try that if I have to change mine out again.
PHP: 7.2.34 Page Time: 0.031s Queries: 16 (0.009s) Memory: 2.8965 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2021-01-15 18:08:59 UTC
