by Trailmonkey - 04/18/21 02:15 AM
by rxinhed - 04/17/21 07:36 PM
Is Pajero Same as Galloper?
per trailer hitch
4D55 Silent shafts
Gordie the Galloper?
per trailer hitch
4D55 Silent shafts
Smoking winch
0 registered members (), 116 guests, and 4 spiders.
Topics138,206
Posts1,081,265
Rating: 1
Page 3 of 7 1 2 3 4 5 6 7
Re: FE3 Build Lists [Re: 2002_Sporty] #957949 10/23/09 04:43 AM
S
sportagebandit Offline
any progress Dennis?
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: FE3 Build Lists [Re: sportagebandit] #957950 10/24/09 06:32 PM
DennisThompson Offline OP
Ya, things are going slow. I was wanting to put the engine in today but my Probe broke yesterday and I allmost burnt it to the ground. Since thats my daily driver right now I have to work on it. I just need to finish cleaning and painting the valve cover and get the flywheel turned and the engine is ready to go in, that was yesterdays projects before the Probe broke. When a have time I will post the pics of the rebuild.
Re: engine rebuild [Re: DennisThompson] #957951 11/09/09 05:47 AM
Ok, I'm going to try to post some pics of building the short block. Last time I tried to post the itemized price list I timed out.
Some of the pics are a little blury, I was using my camra phone.
First you need a good helper. (thats Jake)
Next after everything is good and clean install the freeze plugs.
With a thin film of RTV, I used and old socket and a mallet to knockthem in.
Next I installed the Main berrings.
Put plastiguage on all the crank journals.
Torque all caps to spec, then remove caps and check clearance.
If you don't know how long your engine will sit before you fire it up use assembley lub on your bearings, if you plan to fire it up soon you can use engine oil.
On your final torque put oil on your main bolts before you torque them to spec.
Using a piston push the top ring about half way down the cylinder. Check the end gaps on the rings and if they are to close use a fine file to file them down, mine were all good.
Repeat this step with all rings.
Check ring clearance in pistons also.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0175.jpg[/img]
There are a few ways to install the rings, I like to just carefully work them in starting with the bottom oil ring and working up.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0179.jpg[/img]
If you have a ring installer you ean use it but I like the other way better. I did clean the pistons better before I finished.
Be sure to set your ring gaps right.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0185.jpg[/img]
Using a piston ring compressor squeeze the rings and put the piston in the hole (be sure the front of the piston is facing the forward).
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0183.jpg[/img]
Using the end of a hammer handle, drive the piston home (be carefull the studs don't camage the crank.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0184.jpg[/img]
Use plastigage on rod caps also.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0186.jpg[/img]
make sure your new oil seal is installed corect and bolt on rear cover.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0187.jpg[/img]
Install oil pump.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0189.jpg[/img]
There, now it's a short block. At this point I masked off everything I didn't want paint on and painted the block a High Temp black. I didn't take pics of installling the head but here it is with the valve cover installed.
[img]http://i260.photobucket.com/albums/ii29/upyourkia/engine%20rebuild/Photo0219.jpg[/img]
I hope this will help someone save some money and try to at least assemble thier engine them self. I got all the specs from the Kia manual and the main trick is to keep everything clean.
Re: engine rebuild [Re: DennisThompson] #957952 11/09/09 05:57 AM
Be sure to put plenty of oil on your pistons before you install them, I like to dunk them in a container of oil. somehow that pic got lost. Also make sure you torque everything to spec using the proper sequence.
Hope I didn't miss to much.
Re: engine rebuild [Re: DennisThompson] #957953 11/09/09 06:14 AM
Great info.
Did you polish your valve cover?
If you put short pieces of hose on the con rod bolts, it will protect the crank during assembly.
New oil pump? Did you do anything with the spring to increase tension on the relief valve?
Keep us posted.
Re: engine rebuild [Re: Everet] #957954 11/09/09 03:17 PM
No I just cleaned it good and painted it. The oil pump is new. I didn't know anyting about relief valve spring so thats a no. It is almost ready to put in but I have been working on the Probe so it will pass inspection in Decamber. I don't want to drive the Kia this winter, I have some rust to fix and don't want it to get worse.
Re: engine rebuild [Re: Everet] #957955 11/10/09 12:15 AM
Hydra747 Offline
Thanks for the PICS.....Nice work! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: engine rebuild [Re: Hydra747] #957956 11/19/09 01:59 AM
Cross your fingers <img src="/forums/images/graemlins/smile.gif" alt="" />, I'm planning on putting the engine in Sunday and hope to get it fired up over the Thanksgiving holiday. Nothing else has gone on schedule on this build so wish me luck!
Re: engine rebuild [Re: DennisThompson] #957957 12/01/09 02:01 AM
I will never set goals again! I was doing great on the Kia engine when I went to install the injectors. The air hoses to the injectors split as I was installing them so I had to order new ones from Kia, they will be in Thursday. I put the engine back in the corner and started on my rear bumper. It's turning out great. I have been taking pics so I will post them when it's done.
Re: engine rebuild [Re: DennisThompson] #957958 12/01/09 02:03 AM
jaboo5322 Offline
Keep chuggin. <img src="/forums/images/graemlins/patriot.gif" alt="" />
1989 Dodge W250.
PHP: 7.2.34 Page Time: 0.033s Queries: 16 (0.011s) Memory: 2.9092 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2021-04-18 14:40:16 UTC
