87 Gen1 Rebuild in Kansas
Hankook or Nitto?
by Jx4x4 - 06/30/20 04:13 AM
by polar - 06/27/20 11:11 PM
by polar - 06/17/20 09:19 PM
by - 06/14/20 05:54 PM
Hankook or Nitto?
by Jx4x4 - 06/02/20 04:14 AM
by Ninnnaise - 05/04/20 04:48 AM
0 registered members (), 111 guests, and 6 spiders.
Topics138,122
Posts1,080,664
Members15,072
Rating: 1
Page 4 of 7 1 2 3 4 5 6 7
Re: engine rebuild [Re: jaboo5322] #957959 12/01/09 11:47 PM
Hydra747 Offline
What exhaust components are you looking at?
Re: engine rebuild [Re: Hydra747] #957960 12/02/09 05:12 AM
DennisThompson Offline OP
I think Jake would like Katie! It's the hoses that go from the injectors to the head I need. I did the exhaust just before the engine gave out. it's getting closer though, can't wait to here it run!
Re: engine rebuild [Re: DennisThompson] #957961 12/20/09 07:56 PM
Well, I think I got the Probe ready to pass inspection so after Cristmas it's back to the Kia. This has got to be the longest engine rebuild in history. I just put a windshield in and built an exhaust for the Probe. I had enough pipe left over from the Kia's exhaust to do the whole car, I had a new MagnaFlow left over from my $100.00 Bronco that I sold before I got to the exhaust so I did a whole 2 1/2" cat back on the Probe for about $10.00 in gaskets and hangers. I think I am still under a $600.00 total in the Probe and I put over 20,000 miles in it allready and hit 1 deer, not bad for cheep transportation. Just keeping you up to date on my (none) progress on the Kia. I'll let you know when it makes noise.
Re: engine rebuild [Re: DennisThompson] #957962 12/20/09 09:29 PM
You should have some nice venison steaks out of the deer so hitting it wasn't a total loss <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: engine rebuild [Re: Everet] #957963 12/20/09 09:40 PM
6
69442 Offline
If the deer can not be repaired back to pre-accident condition, technically it would be considered a total loss.
Sounds like Dennis kept the pre-tenderized salvage (steaks), i like mine medium rare please <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: engine rebuild [Re: 69442] #957964 12/20/09 10:06 PM
jaboo5322 Offline
Yes please. <img src="/forums/images/graemlins/drunk.gif" alt="" />
1989 Dodge W250.
Re: engine rebuild [Re: jaboo5322] #957965 12/21/09 01:43 PM
Deer survived, just a little sore. I was already slowed down for the rest of the herd, he was just a stragler, I got back on the gas a little to soon. All it did was brake the rod on the flip-up head light and push the bumper and grill into the hood, a new rod and a crow bar was all in took and the Probe was ok.
Re: engine rebuild [Re: DennisThompson] #957966 12/21/09 03:18 PM
6
69442 Offline
Deer 1 - probe 0
Re: engine rebuild [Re: DennisThompson] #957967 12/23/09 01:41 AM
Hydra747 Offline
Nice shot and work Dennis! <img src="/forums/images/graemlins/kewl.gif" alt="" />
There are 15 bolts to take off of the valve cover....Cause I tried to take off the cam bolts in the back (Everet called and saved my butt)! <img src="/forums/images/graemlins/cheers.gif" alt="" />
What kinda paint did you use?
Did u use break cleaner to remove some of that grease/oil off the outside?
BTW: I purchased all new bolts for the valve cover cause they tend to errode/corrode after time and especially with the heat.
P.S. Some of the high temp silicone prolly ended up mixing with the oil after I performed the gasket Job.........Would you just take the pan off and use a new gasket?
P.S.S. Do you think that it would cause any problems?????
Thanks Denny!
Mikey <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: engine rebuild [Re: Hydra747] #957968 12/24/09 12:36 AM
I used brake cleaner and a wire brush to clean it up, then I used high heat red and painted over the letters, after that I taped off the letters with masking tape and cut them out with an Exacto knife and painted the rest with high heat silver. The paint was Dupli-Color ceramic engine enamel ratted at 500 F. About 3 coats of each color, the block was painted with the same paint, only black.
As long as the RTV doesn't block an oil passage you should be ok. I used RTV only on the oil pan, The gasket kit only came with 1 gasket and with the windage tray you need 2. On the valve cover I would just use a new gasket.
PHP: 7.2.31 Page Time: 0.034s Queries: 16 (0.012s) Memory: 2.8954 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2020-07-09 08:30:21 UTC
