80
Posts1,080,941
Power Door Locks
#964494
09/22/09 08:39 PM
My locks do not work anymore. Can still lock all doors by pushing the locks down by hand, where as before I just had to push down the drivers side lock and all doors locked. Also, when I unlock the passenger side door from the outside it unlocks all but the drivers door for about 2 seconds, then they all lock again.
Any Ideas Guys? Thanks. What an Awesome Site. lol
Re: Power Door Locks
#964495
09/23/09 03:38 AM
take the door cover off and check the conecters of the lock to see if there is corosion on conection, just a guess
[Re: jays2001]
#964496
09/23/09 05:43 AM
It sounds like contact problem. Also, did you leave the window open during a light rain? That might also be the cause, it is is just let it dry out.
[Re: SKC]
#964497
09/23/09 06:43 PM
Pull the fuse for the power door locks to reset the system. If you have a key fob that allows you to unlock the doors you'll need to resetting this too.
[Re: logansportage]
#964498
09/23/09 06:50 PM
just wondering if the rear doors are on a seperate fuse as my rear door locks use to work then they both stopped working at the same time. That is both rear doors front work good.
[Re: budicexxx]
#964499
09/23/09 07:07 PM
SKC - I never leave the windows down, unless I can see it.
logansportage - Pulled the fuse yesterday when I did the window fuse and nothing. Don't have a remote for this one. The key unlocks and locks all doors. When I use the key to unlock the Drivers side door I turn it once to unlock the one door then again to unlock the rest. Now they should stay unlocked but they lock again after about 1 second or so on their own. When I do the passenger door this way it does all but the drivers door for only a second or so, so you need to be fast. Got it down to an art to open both passenger doors...lol...turn, turn, pull handles.
budicexxx - As far as I know my doors are on one 30amp fuse
If I am not explaining this well enough please let me know so I can write it down differently....lol
