80
guests, and 3
1987 toyota drag truck? 7mgte swap? wanna hear some opinions
#967181
10/09/09 10:44 PM
i got a 1987 toyota pickup 2wd 4speed tranny 22r motor i loveeee the truck but hate the slowness, so i know you can drop in a 7mgte and i got a connection into a 7mgte and 5speed tranny with about 400 hp at 18 lbs of boost, which i would prolly only be runnin 10 lbs but any ways would this be worth it? im thinkin that with this tiny truck im gonna have stupid traction problems could they be solved? im lookin to have a good vehicle for street/strip use and also be my daily driver (but at the same time not worried about gas milage)
Re: 1987 toyota drag truck? 7mgte swap? wanna hear some opinions
[Re: yotaman1224]
#967182
10/10/09 03:01 AM
You are likely going to want to run the 18lbs if you are expecting to put down 400hp at the rear wheels. Does the 7m come w/all of the supporting mods for the 400hp?
A couple 100lbs of sand or a water bag over the rear axle should help fix the traction problem.
[Re: Snowtoy]
#967183
10/10/09 06:16 AM
Yea dude...do it. I want to get a 90's 2wd truck and put a big HP engine in it....either 7mgte or 1uzfe. Almost enough to sell my 88 4Runner..
Might want to upgrade to at least a 4wd 8" rear axle. Build a trackbar and some heavier duty leafs....or better yet, build a 4link setup.
[Re: Adam F]
#967184
10/10/09 08:18 AM
yeah he has the 7mgte with metal head gasket studded head aftermarket intake and exhaust manifolds, big injectors and big turbo and wiring harness and ecu with a 10 and 18 lb tunes he said he was makin just over 400 to the wheels on the 18lb tune but i'd prolly only turn it that high on saturday nights or at the track
[Re: yotaman1224]
#967185
10/10/09 04:24 PM
Has anyone ever considered a 1jz-gte? I have seen half-cut supra's from japan for sale on the ebay motors for $1500. Now that would really wake it up.
[Re: oldskoolkrome]
#967186
10/11/09 01:14 AM
Supratrucks, has write-up on both of the installs.
[Re: Snowtoy]
#967187
10/11/09 01:50 AM
My 2WD build will have a 7Mgte est 400HP .. full custom frame with IFS & IRS ![[Linked Image]](http://www.members.shaw.ca/slacker502/images/IM000600.JPG) ![[Linked Image]](http://www.members.shaw.ca/slacker502/IM001112.JPG)
[Re: CJM]
#967188
10/11/09 02:00 AM
thanx for the site reference it will be a big help
[Re: yotaman1224]
#967189
10/11/09 07:59 AM
CJM how hard is it to do that idependant rear stuff?
[Re: yotaman1224]
#967190
10/12/09 12:22 AM
