80
guests, and 3
FITTED ELECTRIC BRAKES TO SPORTY
#982743
01/27/10 09:25 AM
Hi all, Finnished fitting up electric brakes to my Sporty on Monday. Fitted a remote head Red Arc unit. It was a tight fit to fit both LED and controller in the one switch panel <img src="/forums/images/graemlins/scared.gif" alt="" />. but managed it with the help of a soldering iron to trim back some plastic inside the blank switch panel. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Here is a pic of the finished result installed. Nice and neat, easily accesible to adjust brakes and no bulky controller in the cabin (hidden under dash <img src="/forums/images/graemlins/butwiggle.gif" alt="" />) Cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" /> ![[Linked Image]](http://i217.photobucket.com/albums/cc190/4runnernomore/PICT01055.jpg)
Re: FITTED ELECTRIC BRAKES TO SPORTY
[Re: 4runnernomore]
#982744
01/27/10 04:08 PM
Really nice job man. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: jaboo5322]
#982745
01/27/10 10:43 PM
[Re: jaboo5322]
#982746
01/28/10 01:53 AM
Really like the custom look!!!
Wish I could get 2 or 3 of the fog light switches like yours. Haven't seen them available here (USA) on Sportages.
[Re: Everet]
#982747
01/28/10 09:27 AM
Ditto, on the switches. I really enjoy looking at quality custom projects. Looks like it's supposed to come like that from the factory. Impressive. Thank you for the photos. If you or any one knows where to find stock looking rocker panels to house our auxillary/rocker switches please state your sites.
[Re: 2002_Sporty]
#982748
01/28/10 01:15 PM
The rocker switch with the brake setup is one of the blanks. I purchased the other switch from the stealership about 2 years ago to use as a driving light switch. Got the idea from the OZKIA website. http://www.ozkia.com/ The site hasn't been active for a while but it is a good read. The fog light switch wasn't that expensive from memory and does look flash fitted. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I will probably end up pulling the top sticker off to neaten up the install on the brakes switch. Cheers,Chris
[Re: 4runnernomore]
#982749
01/29/10 06:49 AM
Very nice... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sportage, 75mm lift, 30"s A/T,UHF& HF, AVM hubs and more to come.
[Re: FOURSKIA]
#982750
04/03/10 12:23 PM
Hi All, the reason for my electric brakes. <img src="/forums/images/graemlins/wink.gif" alt="" /> ![[Linked Image]](http://i217.photobucket.com/albums/cc190/4runnernomore/DUNNESSWAMP1.jpg) And you can just see the hitch reciever on the mighty little Kia. It is a TRIGG poly hitch. ![[Linked Image]](http://i217.photobucket.com/albums/cc190/4runnernomore/DUNNESSWAMP7.jpg) Cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: 4runnernomore]
#982751
04/16/10 02:32 AM
Nice! How does it weight? How much do you think you're pulling with the luggages, food, water, etc.? Do you have enough power? How many people travelling with you? How bad does it get when you drive uphill?
[Re: sportedge]
#982752
04/19/10 09:40 AM
Around 900 kg on that trip and approx 500-600kg in the Sporty with a family of four and gear.
Heading over the blue mountains out of Sydney is very steep in places seeing me back to first on a few occasions but second and third for most of the inclines.
The Sportage has enough power most of the time till you hit the hills and you will be rowing the box (mine is manual)I would like to get extractors and decent straight through exhauast to help it along. She will sit on 110+ km on the freeway no worries at all with more to give and will accelerate away but slows qucickly on inclines. The trick is pick your gears to keep momentum on your side and keep her above 2700RPM otherwise she sheds speed at a rate of knots.
I would take her offroad in gentle conditions that are not to steep or rugged and sand would be out of the question. Dirt roads and formed tracks not a problem but have a recovery vehicle if you are getting adventurous.
I have certainly surprised a number of people towing my camper and how well the Sporty handles it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Suspension would be good though along with AIRBAGS in the rear. <img src="/forums/images/graemlins/scared.gif" alt="" />
