guests, and 3
Topics138,274
Posts1,081,733
Cluch is sticking on my 95 4runner?
#985559
02/15/10 07:34 PM
I just replaced it about a year ago and was woundering if anyone had a solution? 1995 4runner 35x12.50 3.0 4x4
Re: Cluch is sticking on my 95 4runner?
[Re: 4runTAZ]
#985560
02/16/10 01:17 AM
2 suggestions:
1 - Call the shop that did the work 2 - run smaller tires
Rick 1984 4Runner
[Re: 4runTAZ]
#985562
02/16/10 06:31 AM
What do you mean by sticking clutch? You press the pedal down, and it sticks to the floor? If so, its either your clutch master or slave cylinder. Go ahead and rebuild/replace BOTH. They are cheap.
[Re: Adam F]
#985563
02/18/10 12:25 AM
When ever i push in the cluch it only sticks sometimes but seems like its happening more and more cause im have to pop it back up with my foot. I have 4.56 gears and im thinking i might just have to get 5.29 if this is gona keep on happening.
[Re: 4runTAZ]
#985564
02/18/10 02:28 AM
That won't fix it. Just go get the gears anyway! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: 4runTAZ]
#985565
02/18/10 04:45 AM
Gears have absolutely nothing to do with it. Either do tires <img src="/forums/images/graemlins/confused.gif" alt="" />
Your clutch hydraulics are bad. I had the exact same problem. I rebuilt my clutch master cylinder. Didn't fix it. I then replaced my clutch slave cylinder and problem solved.
[Re: Adam F]
#985566
02/18/10 07:00 AM
Ill get back at ya when i do it this weekend and see if anything has changed and if not ima just have to wait about a month to get gears from my bro, hes doing a solid axle swap on his yota.
[Re: 4runTAZ]
#985567
02/19/10 12:57 AM
You want 5.29 gears with 35" tires.
A new master/slave will fix your problem, trust me.
[Re: Adam F]
#985568
02/23/10 05:43 PM
A new master/slave will fix your problem, trust me. I'm having the same problem My clutch MC is aisin and slave is autozone both at 2 years old. Think i should switch back to an aisin slave?
