the cold start shuffle got me
0 registered members (), 61 guests, and 6 spiders.
Topics138,274
Posts1,081,733
SAS In the Rearview Mirror? #993678 04/13/10 03:37 AM
Jim_Paget Offline OP
This thread is directed at those of you who have completed a SAS on an Isuzu.
Please recap the following:
What vehicle type and year?
Axle Used
Leaf or Coil?
If Leaf,
Spring over or under?
Locker? If so, which one?
How did you handle the steering issues?
In retrospect, what would you do differently?
If you have a link to a discussion of you build, please include it.
While I have a personal interest in the topic, I would like this thread to be a resource for anyone contemplating doing a SAS
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: SAS In the Rearview Mirror? [Re: Jim_Paget] #993679 04/13/10 02:14 PM
RobG Offline
I'll start...
What vehicle type and year? 1995.5 Rodeo
[/b]Axle Used[/b]
front: v1 - waggy D44 converted to 8 lug. v2 - dodge D60
rear: v1 - cab n' chassis 14-bff. v2 - swap out to srw hubs
Leaf or Coil? Leaf, started out with wagoneer 4-pack
If Leaf,
spring over, shackle reversal.
D44 was an OX then D60 a full spool.
D44 - histeer using SRE's. D60 - histeer w/ behind the knuckle tie rod and using ball joints.
dialing in the front spring rate as been difficult, battling firmness vs height, though flex never has been a problem. length and angularity for the front driveshaft has been a big concern with shackled reveresed SOA, probably my number 1 challenge in the project. some sort of histeer/crossover was a must. a few problems with undersized braking components after changing out the calipers on all four corners.
I try to post pictures to all my projects at my website, www.zu4x.com, however, i've been having some difficulty mantaining the site lately and my gallery is currently down.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: SAS In the Rearview Mirror? [Re: Jim_Paget] #993680 04/13/10 04:39 PM
D
dvtrooper Offline
Vehicle 88 trooper2
Axle Dana44 posi
Leaf/sua
rear spring over, ome springs, aussie locker
steerin/ flat top knuckes
what would i do different/ not much at this point i can drive it on the street and rides pretty good, tires make a big difference, i use to have dunlop mud rovers and now have km2 the km2 handles on the street very nice. Don
sua dana 44 conversion 5.38 gears, 4.3tbi,700r,dana 300 w/tera low 4:1 gears
Re: SAS In the Rearview Mirror? [Re: Jim_Paget] #993681 04/14/10 06:12 AM
maxwell417 Offline
1990 Trooper
Dana 44 3/4 ton narrowed and converted to 6 lug ARB 5.38s.pinion rotated up. Bought it from Travis after he went D60.
Trooper stock rear leaves up front, shackle forward, Ford pickup shock towers, spring over axle. Timbren bumpstops.
Stock steering box, crossover. The axle is about 5" forward of stock position.
2" spacers on the rear axle Isuzu 12 bolt to widen the track to match the front.
I never made any effort to pursue extreme suspension travel. I have always been happy with the rear suspension flex. So using rear leaves up front figured I'd be happy, I was right smile
Biggest problem for me, was figuring out that I really needed a rear cv driveshaft. Shimmed the rear axle up & new cv driveshaft,no more highway vibes.
To regain 4 hi use. I should get a cv front shaft also.
No build thread .... just some pictures
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: SAS In the Rearview Mirror? [Re: maxwell417] #993682 04/17/10 04:49 AM
http://www.4x4wire.com/forums/showf...;amp;page=0&fpart=1&vc=1
That is a link to Houlster's amazing linked axle swap.
Jim Paget
www.rrr4x4.com
Re: SAS In the Rearview Mirror? [Re: Jim_Paget] #993683 05/03/10 06:26 AM
94rodeo Offline
94 rodeo
dana 44 from wag originally, now a dana 60
went with coils
started with a lockrite, then arb, now open
Handled great with the dana 44, could drive highway speeds, now i need to dial in the dana 60, been about a year that i have needed to do some adjusting, just not enough time
In retrospect, what would you do differently? Do the dana 60 in the first place and a full float rear
no, just pics at webshots
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: SAS In the Rearview Mirror? [Re: 94rodeo] #993684 11/26/10 05:43 AM
I
Idaho_Trooper Offline
1988 Trooper
79 Wagoneer D44, 5.38s open
SUA front and rear
Toyota FJ40 front springs on front
Jeep shackles (aftermarket)
Trooper rear bumpstops on front
stock rear springs with Indy4x add a leaf and Calmini shackles
Isuzu 12 botl rear, 5.38s, LSD
Tera Lows
custom steering (.25" wall, 1.5" DOM tubing for steering links
modified pitman arm
relocated oil filter
36" Swampers on 15x10 black rockcrawler rims
Poly bushings throughout
Once I replaced all the bushings with poly, the thing drives really well!! I agree that tires make a difference, and will be changing mine soon.
Overall, i really enjoy the truck. I will say that a small part of me misses the IFS due to the fact that I liked to prove to the J$$ps that IFs could do it too. The new project will stay IFS.
I can still do 70 on a level freeway, and running around town is no problem.
James "MOZES" Tester
1988 Trooper SAS
Re: SAS In the Rearview Mirror? [Re: Idaho_Trooper] #993685 11/29/10 07:28 PM
R
Rodeo Clown Offline
What vehicle type and year? 1994 Rodeo
Axle Used Front: 79 Waggy D44 Rear: Stock D44
Leaf or Coil? Front springs from the same jeep with the shackles in the rear.
If Leaf, Spring over or under? Spring over
Locker? If so, which one? Lockrite with 5.38s
How did you handle the steering issues? Standard crossover. I found out later that the steering arm needed to be redrilled closer to the center of the knuckle to allow lock to lock steering due to stubby pitman arm.
In retrospect, what would you do differently? I would have drilled the arm before I put all the dents in the doors.
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: SAS In the Rearview Mirror? [Re: Jim_Paget] #1105742 10/01/20 10:06 AM
L
lupacexi Offline
Thanks you for sharing
lupacexi
PHP: 7.4.29 Page Time: 0.012s Queries: 15 (0.005s) Memory: 2.9005 MB (Peak: 3.1929 MB) Data Comp: Off Server Time: 2022-05-26 12:19:44 UTC
