Water temperature sensor
Happy Holidays
by plh - 12/29/21 11:04 PM
V5MT1 Confusion
Early Gen I trim levels
Happy Holidays
2 in lift kit worth it?
0 registered members (), 67 guests, and 6 spiders.
Topics138,255
Posts1,081,614
Members15,239
having a issue , #994642 04/22/10 03:15 PM
catman25 Offline OP
went to dunn tire and the tech said my tire was about to fall off and to tow it home , i just had the idler arm replaced and the all front wheel bearing replaced so i thought he was full of it! went to expert tire 2 hrs later and they aligned it no problem , with no mention about any issues < prior to going to expert my mechanic jacked it up and verifed nothing is about to fall off , But now i have a issue , i just got it alighned but it still swerves to the right , i havent rotated my tires yet would/could that be the reason ? also i know my right stut probly needs to be replaced , Its wierd it feels like there is play right in the middle like it sloppy , is there a part that typically creates this issue ? It just suprises me one place lies and says its about to fall off" accident waiting to happen " and another place does it and doesn tmention any issue but there clearly is , ne ideas? on this ? I jack up front did the wheel bearing check as well as balljoint check and it seems solid but something is up . could bad strut really cause this issue ? thanks mates
check out my truck and please sign my guest book *CHECK OUT MY RIDE*
Re: having a issue , [Re: catman25] #994643 04/22/10 09:17 PM
J
jimmybjames Offline
a bad strut can make it feel sloppy and a broken one could make it feel like the wheel is going to fall off. Tires are a big part of it as well. Try to rotate them or get a couple new ones up front. Also there are lots of hacks out there who just want your money and will tell you all kinds of things are wrong to get it. If you dont know someone who can look at it for you look up reviews on the place you plan to take it.
Re: having a issue , [Re: catman25] #994644 04/23/10 02:18 PM
2002_Sporty Offline
Sounds like a strut problem from what you have said. I had a few vehicles with one bad front strut and they all pulled to one side. One car was so damn dangerous to drive I had to park it. I was dumbfounded till my father in law mentioned it. The car sat fine on the struts, didn't look like a droop or anything. I even sat on each side of the hood, jacked up the car and couldn't find anything. Finally changed out the struts, and sure enough... Darn thing worked fine. Hope yours is an easy fix. Good luck.
2002 4dr Kia Sportage 4X4
Re: having a issue , [Re: 2002_Sporty] #994645 04/23/10 04:07 PM
catman25 Offline OP
well rotated tires and drives better aligned but new problem , took it back to dunn tire and assk them to recheck and they showed me what they were talking about the lifted truck by the strut bottom so there was no tention on the tire and there is play !!!!. but if you lift truck with tension on tire there is no play . can any confirm this check ???
Re: having a issue , [Re: catman25] #994646 04/24/10 01:11 AM
Lou Offline
Can you locate the origin of the play ? Are you sure the new wheel bearings are properly pre stressed with the adjustment of the spindle nut ?
PHP: 7.2.34 Page Time: 0.027s Queries: 15 (0.008s) Memory: 2.8422 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2022-01-16 19:14:48 UTC
