97
Posts1,080,940
funny trans issue...
#997091
05/16/10 03:03 AM
Well, my t is getting old, quick. I have an A/T an extra tranny cooler, and the FAL fan to keep the trans cool. Even in the summer my atf never goes over 140. (I put in a temp gauge too) I noticed the shifts from drive to reverse is causing a rather harsh hook up, with a bit of a clunk and sudden engagement. I am thinking about getting the fluid flushed and filled but I am wondering if this is a bad sign....
currently on the list of stuff that has to get done is a new cat, and a reman right axle for the busted cv, and two new tires...
Re: funny trans issue...
[Re: dogslovetrucks]
#997092
05/16/10 09:31 AM
Put some Auto-RX in there first...run it fer the 1000 miles and then do yer drain/flush. <img src="/forums/images/graemlins/wink.gif" alt="" />
#997093
05/19/10 08:33 PM
Check your drive shaft u-joints
[Re: Adam F]
#997094
05/25/10 03:40 AM
Yep... it was the rear u-joint. the mech (who I seem to like at this point) said the last u joint was shot, replaced it and said all is good in the world... looks like I am getting two more tires, and a reman axle and I am on my way... I have been getting about 75K out of my BFG A/T KOs. Still have some meat left but not much... I am starting to worry that the front end will wash out when it is rainy out
Re: funny trans issue... *DELETED*
#997095
05/25/10 03:48 PM
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
[Re: garym]
#997096
05/25/10 11:51 PM
I have not driven it yet, but the mech says that it is a world of difference. I will probably put a big trip on it this weekend and have a full report...
