Search E-Bay for your parts:
Search Amazon for your parts:
WTB - Montero 3.0L Fan Clutch 89-94
by rxinhed. 01/23/19 07:25 AM
1989 LS Montero -K148 Transmisson-No OD
by rxinhed. 01/23/19 07:22 AM
Headlight & Rear window washers
by rxinhed. 01/23/19 07:19 AM
Where to advertise selling a 1990 SWB Montero?
by rxinhed. 01/23/19 07:16 AM
Gen 1 LWB brake lights not working.
by rxinhed. 01/23/19 07:14 AM
My first Raider
by rxinhed. 01/23/19 07:02 AM
22re randomly starts then dies . . . repeatedly
by Bevoman. 01/22/19 11:22 PM
2nd Gen Front Lincoln Locker.
by Bruce Anderson. 01/14/19 03:24 PM
Hello from Vermont & Gen II SWB diesel
by ATTILA. 01/13/19 01:29 PM
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
WTB - Mitsubishi OD Relay MB510843
by tdf46. 01/09/19 03:56 AM
How to connect to ECU for diagnostics
by chadzeilenga. 01/08/19 02:22 AM
Flex test after suspension mods
Clearance check!
0 registered members (), 128 guests, and 6 spiders.
Topics137,963
Posts1,079,882
Members14,875
Most Online581
Apr 3rd, 2017
Page 4 of 4 1 2 3 4
Re: Winch w stock bumper [Re: Guns_and_Roses] #981388
02/11/10 03:52 PM
02/11/10 03:52 PM
lordtrunks  Offline
Apache Jct, Arizona,USA *****
not sure if your talking bout mine or his but mine came off a full size truck its about 30 years old. These worm gear winches are awesome very slow but like the m.m. hyd. winches you can just rip houses down all day long without a break and they don't care, only thing is our alts can't keep up with them or any winch so all day winching is out.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Winch w stock bumper [Re: Angelo] #981389
02/11/10 04:48 PM
02/11/10 04:48 PM
87Montero  Offline
Greenville, SC ***
Quote
first off, TJM is very rare to even find on a vehicle. Second, you found one at a junk yard. Third, you got it for $50!! You were extremely lucky! Sweet find for sure! Glad to see you aren't wasting any time. Is that the new "Marn" winch? <img src="/forums/images/graemlins/lol.gif" alt="" />
Yeah I'm kind of jealous!!! I wish I got my new TJM for $50! <img src="/forums/images/graemlins/scared.gif" alt="" />
1999 Mitsu Montero - Crappy Weather
1992 Isuzu Pickup - Zombie Apocalypse
2008 Saturn Sky Redline - Nice Weather
Re: Winch w stock bumper [Re: LandRaider] #981390
02/11/10 05:30 PM
02/11/10 05:30 PM
hazy_daze  Offline
Athens, Georgia *****
Quote
What did that winch come from?
They're typically found on wreckers and tow trucks. Work REALLY good.
Fasteddy's advice is occasionally sound...
Re: Winch w stock bumper [Re: 89montero] #1104156
02/03/18 05:13 AM
02/03/18 05:13 AM
djacidjac  Offline
PA USA
I bought a harbor freight winch and winch plate, then cut the plate in such a way that the "L" shaped pieces cut off each end stand up vertically (and get welded on). I bolted the flat plate to the bottom of the frame at the factory winch mount holes, and I bolted the new 'uprights' to the inner sides of the frame at the factory weld-nuts there. those require half-inch spacers because the frame rails get narrow right there. I used some short pieces of pipe "temporarily" for several years and haven't had the need to put a flat piece of half-inch steel in there like I intended. I have used this setup to winch the Raider out stuck good a few times and some other trucks mildly stuck and a whole bunch of weird / fun utility stuff. A note about the old HF winch I got; they made their own solenoid switching assembly, it's pretty beefy with thick brass plates and contactors. It only uses two solenoids in a push/pull arrangement and that's how it can reverse. The whole switching can be rebuilt using only a small flat-blade screwdriver. I remotely mounted the solenoids under the hood so the winch would fit under the Raider body. I still had to trim the plastic winch clutch lever a tiny bit but I had no issues with that** I have a 2-inch body lift now, so there's plenty of room, but It fit before the body lift (barely**) with half-inch shims to lower the winch frame. (removed shims after body lift installed).
-almost forgot, I had to cut about 3/4 inch off the rear of the factory front tow hook to get my plate to fit. I used a sawsall patiently and it was super clean. sorry, no close up pic of that. maybe tomorrow in the light.
I'll attach a bunch of pics of it. Sorry they're at night with a flashlight, but I think they get the important info across.
PS this is an old thing, I just am getting back into my Raider and am catching up on some stuff I always meant to share.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: Winch w stock bumper [Re: 89montero] #1104157
02/03/18 05:14 AM
02/03/18 05:14 AM
djacidjac  Offline
PA USA
3 more pics
Re: Winch w stock bumper [Re: 89montero] #1104159
02/03/18 05:15 AM
02/03/18 05:15 AM
djacidjac  Offline
PA USA
3 more more pics
Re: Winch w stock bumper [Re: 89montero] #1104160
02/03/18 05:18 AM
02/03/18 05:18 AM
djacidjac  Offline
PA USA
last 1 pic
oh, bonus!; I used an old body mount bushing as a cushion between the hook and the fairlead so I just pull the winch in untill it snugs and all good. no rust or noise and no hook yanked against a d-ring or anything. looks tidy too. This setup could use some reinforcing on the bumper/fairlead, but, you know, I'll get right on that.
Re: Winch w stock bumper [Re: 89montero] #1104165
02/03/18 07:09 PM
02/03/18 07:09 PM
rxinhed  Offline
Gerber, CA *****
Good job
1988 Mighty Max turbo 2.6 service body
1980 Power Wagon W400
Sundry Mitsubishi Montero Gen 1 parts, Gen 1 and Gen 2 Max parts
Parts vehicles: 89 LS Montero 4-door, 2002 Sport AWD
For Sale: 1989 Power Ram 50 extended cab, #277 Montero
Re: Winch w stock bumper [Re: 89montero] #1104168
02/05/18 04:33 AM
02/05/18 04:33 AM
0778drz110  Offline
SARASOTA, FL
Nice work. I've had a 10K HF winch for 7 years now, still works. I haven't used it a ton, but I have had to use it and I got my $300 out of it.
'88 Raider, 33" swampers, 2" body lift, 10K winch
Page 4 of 4 1 2 3 4
Moderated by  Macka, Mudraider, off-roader, PajEvo, rxinhed
OutdoorWire Websites
Portal page for OutdoorWire Access and Landuse Central Read More
California off road recreation news and information Read More
MUIRNet News
MUIRNet News
News and information about issues affecting outdoor recreation Read More
Off road recreation and 4x4 Technical news and information Read More
TrailTalk
TrailTalk
4x4Wire TrailTalk Forums for a variety of 4x4 tech information Read More
4x4Wire Tech Section
Jeep 4x4 Tech
Jeep 4x4 Tech
Jeep Tech from JeepWire - Mods, Maintenance, Tech and more... Read More
Isuzu 4x4 Tech
Isuzu 4x4 Tech
Isuzu Tech from 4x4Wire - Mods, Maintenance, Tech and more... Read More
| 4x4Wire on FaceBook | Google+4x4Wire on Google+|
Copyright (c) 1999-2017 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Page Time: 0.017s Queries: 21 (0.007s) Memory: 1.1057 MB (Peak: 1.2419 MB) Zlib disabled. Server Time: 2019-01-23 21:57:52 UTC
