Search E-Bay for your parts:
Search Amazon for your parts:
by rascott. 02/21/19 02:19 AM
Intermittent No-Start & Stalling
by Casey. 02/20/19 12:49 AM
1989 4Dr - LS V6 - For Sale
by tdf46. 02/19/19 07:49 PM
Rebuild a Power Steering Pump
by Bigshankhank. 02/19/19 01:44 PM
4D56 into Mazda B2600i swap thread
by JeffatTireBalls. 02/18/19 06:30 PM
Upgrade City
by DRTDEVL. 02/16/19 03:53 AM
Re-installing tranny in Gen1 SWB
by GrantCee. 02/10/19 11:20 PM
Upgrade City
by 87Raider. 02/11/19 04:55 AM
1989 12v SOHC - Valve Train Noise
by tdf46. 02/01/19 09:03 PM
Buy my 1988 Montero!
by DRTDEVL. 01/30/19 09:29 PM
Tailgate Hinge Assembly: Part No & Diagram?
by Crops. 01/30/19 08:17 PM
Flex test after suspension mods
0 registered members (), 122 guests, and 5 spiders.
Topics137,972
Posts1,079,928
Members14,882
Most Online581
Apr 3rd, 2017
Page 5 of 5 1 2 3 4 5
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026891
03/02/12 07:09 PM
03/02/12 07:09 PM
LandRaider  Offline
Forum Moderator
Ocean Springs, MS *****
on my 231 I hacked the handle off the shifter, and welded on a chromed steel rod that was bent like I needed it to be. I slotted the floorboard with a jigsaw, and then used some rubber matting with a slit in it to work as the floor seal. Then I got a K5Blazer Boot, and used it to cut out a ring, and screwed that all to the floor.
87 Raider 4D56td v5MT1
31's..Basically Stock
Re: Gen1 Transfer Cases Options [Re: LandRaider] #1026892
03/02/12 07:11 PM
03/02/12 07:11 PM
LandRaider  Offline
Forum Moderator
Here's a pic. Notice the location... This is with a 700r4, and GM motor, so it has little bearing on where yours would need to go.
http://alliedpaper.org/landraider/SASpics%20%2812%29.JPG
LARGE picture
Re: Gen1 Transfer Cases Options [Re: LandRaider] #1026893
03/02/12 08:01 PM
03/02/12 08:01 PM
RECON45  Offline OP
Statesville, NC
Very clean. If I had carpeting for mine, I might would consider that route. I think I got most everything figured out now. it is now a matter of having a few clear weather days to work on it to get everything swaped. Thanks for the input and picture.
91 Montero LS "Sandstorm", Auto, Dual Bouncy Seats, 2" Suspension lift, 2" Body Lift, GENII front IFS, 32" MT tires
89 Raider "Trailbreaker", 3.0, Auto, Dual Bouncy Seats
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026894
03/06/12 09:34 PM
03/06/12 09:34 PM
RECON45  Offline OP
Statesville, NC
I will try to get pictures but I have a mcmaster carr shifter and 6' cable to use for my shifting. i need to fab a bracket for the shifter to hold it to the floor and a bracket for the cable part to the Tcase. there really is much of a place to set up a bracket that bolts up to the tcase. i will try to get pictures. I want to see if I can use the factory shifter knob on the new set up. i might have to mod it a little bit.
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026895
03/07/12 03:03 AM
03/07/12 03:03 AM
Mudraider  Offline
Orange Park, FL
I got my Dana 300. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen1 Transfer Cases Options [Re: Mudraider] #1026896
06/05/12 10:20 PM
06/05/12 10:20 PM
dsmguy  Offline
Texas
the 4cyl raider transfercase and upgrade for the mighty max? the only thing i see different is that is has the nuetral position and mine does not.
89 Raider V6 5 speed factory lsd rear
88 mighty max 4 cyl. 5 speed
Re: Gen1 Transfer Cases Options [Re: RECON45] #1104154
02/03/18 04:31 AM
02/03/18 04:31 AM
djacidjac  Offline
PA USA
I'm exploring options. I was hoping to fit some kind of under-drive box like the BlackBox from NorthWest Fabworks. I've been googling for a couple of hours and all I can find is some vague "23 spline" talk.
Does anybody know for sure what are the shaft specs on a gen 1, 2.6, manual KM-145 transmission:
1. transmission output shaft
a. diameter
b. spline count
c. usable/spline length
2. transfer case
a. (will be same as above)
b. (will be same as above)
c. usable/spline depth
3. any other info related (such as what adapters or cases have the same bolt pattern, what model name/number the transfer case is, etc)
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: Gen1 Transfer Cases Options [Re: RECON45] #1104164
02/03/18 06:50 PM
02/03/18 06:50 PM
rxinhed  Offline
Gerber, CA *****
Mark's in Australia sell a 2.85 low gear set. They've had 3.15 in the past. Look up Toasty or Josh on Adventure Driven Design (.com), as I believe they're marketing the kits.
1988 Mighty Max turbo 2.6 service body
1980 Power Wagon W400
Sundry Mitsubishi Montero Gen 1 parts, Gen 1 and Gen 2 Max parts
Parts vehicles: 89 LS Montero 4-door, 2002 Sport AWD
For Sale: 1989 Power Ram 50 extended cab, #277 Montero
Moderated by  Macka, Mudraider, off-roader, PajEvo, rxinhed
OutdoorWire Websites
Portal page for OutdoorWire Access and Landuse Central Read More
California off road recreation news and information Read More
MUIRNet News
MUIRNet News
News and information about issues affecting outdoor recreation Read More
Off road recreation and 4x4 Technical news and information Read More
TrailTalk
TrailTalk
4x4Wire TrailTalk Forums for a variety of 4x4 tech information Read More
4x4Wire Tech Section
Jeep 4x4 Tech
Jeep 4x4 Tech
Jeep Tech from JeepWire - Mods, Maintenance, Tech and more... Read More
Isuzu 4x4 Tech
Isuzu 4x4 Tech
Isuzu Tech from 4x4Wire - Mods, Maintenance, Tech and more... Read More
| 4x4Wire on FaceBook | Google+4x4Wire on Google+|
Copyright (c) 1999-2017 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Page Time: 0.013s Queries: 17 (0.005s) Memory: 1.0511 MB (Peak: 1.1738 MB) Zlib disabled. Server Time: 2019-02-21 18:44:35 UTC
