Search E-Bay for your parts:
Search Amazon for your parts:
Starter motor are they serviceable ..
by rxinhed. 04/17/18 03:14 AM
Considering Part-Out...
by rxinhed. 04/12/18 12:34 AM
by rascott. 04/11/18 08:44 AM
1999 Montero Sport Limited 3.5L crawler build
by ES_97Sport. 04/11/18 12:56 AM
4D56 into Mazda B2600i swap thread
by JeffatTireBalls. 04/08/18 02:57 PM
87Monty will have a 4BT
by JeffatTireBalls. 04/08/18 02:50 PM
Tuning up 4D56T
by red1987raider. 04/02/18 12:41 AM
by 4runnernomore. 04/16/18 01:49 PM
by DRTDEVL. 04/06/18 02:04 PM
Tuning up 4D56T
R&P Contact Pattern
by JeeperDan. 03/15/18 01:14 PM
by rxinhed. 05/01/16 12:11 AM
Flex test after suspension mods
Clearance check!
Testing the new Kenda Klever 31x10.50x15
My '88
4x4Wire YJ
0 registered members (), 43 guests, and 4 spiders.
Topics137,824
Posts1,079,359
Members14,753
Most Online581
Apr 3rd, 2017
Battery and Brake lights on #1103892
10/04/17 11:52 PM
10/04/17 11:52 PM
T
toyomorph  Offline OP
CO
Hi guys - well my truck has been ultra reliable until now. It;s a 93 reg cab 22R 4x4. I was washing the front of the engine and top of the front diff and some areas in the engine compartment yesterday after oil change.
I use dawn in a spray bottle and the garden hose. No high pressure. I have done this many times. I let it dry for a while and then closed the lid and parked it in the driveway.
This morning I started it up and I have the brake and battery light on. So I checked the voltage across the battery terminals and it was 12.6vdc.
Started it up and checked and it was 12.1 and rev'd up to around 2k and it stayed there. Not charging. So after reading all about this I pulled the alternator and checked the brushes. they measured .254 inch with
minimum being .177... so the brushes are good. With only 120K miles on the truck I was thinking they would be.
So I checked out the 80 amp alt fusible link in the fuse box and pulled the fuse box of and took the bottom off to inspect inside and all looks normal. I even pulled out the link and looked the wires over pretty good.
I know I didn't have to check it as the truck starts and runs, but wanted to see under the fuse box.
The connector to the alternator looks very good, the pins look good on the alternator, the positive wire looks good and was nice and tight.
Guess it could be the regulator in the alt.
Tomorrow I am taking the alternator to a alt shop to have it tested. I will take the battery to Autozone and have them test that.
My question is , if these turn out to be ok then could it be a problem with the ignition switch? or something else?
Appreciate any help you can offer... respectfully.
canyon country explorer
1993 4x PUP
From the Off-Road World
Re: Battery and Brake lights on [Re: toyomorph] #1103899
10/06/17 09:01 PM
10/06/17 09:01 PM
4x4Wire  Offline
Lakeside, CA ***
I would go back to the the wash job and check connections and wiring.
Starting is possible with a bad alternator. No indicating of charging is a sign of problem.
If teh alternator tests good, check ground connections....
Re: Battery and Brake lights on [Re: 4x4Wire] #1103903
10/09/17 07:59 AM
10/09/17 07:59 AM
Snowtoy  Offline
Grass Valley, CA
Sounds like you washed muck into the alternator, it may dry out if you only got water in it, if oil/sludge it will need to be rebuilt/replaced.
More than tread lightly. Leave it like you were never there, nor anyone else.
'90 X-cab 4.88's 33 BFG AT's, rr ARB, Headers, Ignition upgrade, cold air induction.
'91 X-cab 5.29's 315's BFG MT's, rr ARB, custom bumper and flatbed
Moderated by  4Crawler, kewlynx
OutdoorWire Websites
Portal page for OutdoorWire Access and Landuse Central Read More
California off road recreation news and information Read More
MUIRNet News
MUIRNet News
News and information about issues affecting outdoor recreation Read More
Off road recreation and 4x4 Technical news and information Read More
TrailTalk
TrailTalk
4x4Wire TrailTalk Forums for a variety of 4x4 tech information Read More
4x4Wire Tech Section
Jeep 4x4 Tech
Jeep 4x4 Tech
Jeep Tech from JeepWire - Mods, Maintenance, Tech and more... Read More
Isuzu 4x4 Tech
Isuzu 4x4 Tech
Isuzu Tech from 4x4Wire - Mods, Maintenance, Tech and more... Read More
| 4x4Wire on FaceBook | Google+4x4Wire on Google+|
Copyright (c) 1999-2017 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Page Time: 0.009s Queries: 16 (0.003s) Memory: 0.9878 MB (Peak: 1.0616 MB) Zlib disabled. Server Time: 2018-04-21 17:27:19 UTC
