Search E-Bay for your parts:
Search Amazon for your parts:
by rascott. 02/21/19 02:19 AM
Intermittent No-Start & Stalling
by Casey. 02/20/19 12:49 AM
1989 4Dr - LS V6 - For Sale
by tdf46. 02/19/19 07:49 PM
Rebuild a Power Steering Pump
by Bigshankhank. 02/19/19 01:44 PM
4D56 into Mazda B2600i swap thread
by JeffatTireBalls. 02/18/19 06:30 PM
Upgrade City
by DRTDEVL. 02/16/19 03:53 AM
Re-installing tranny in Gen1 SWB
by GrantCee. 02/10/19 11:20 PM
Upgrade City
by 87Raider. 02/11/19 04:55 AM
1989 12v SOHC - Valve Train Noise
by tdf46. 02/01/19 09:03 PM
Buy my 1988 Montero!
by DRTDEVL. 01/30/19 09:29 PM
Tailgate Hinge Assembly: Part No & Diagram?
by Crops. 01/30/19 08:17 PM
Flex test after suspension mods
0 registered members (), 133 guests, and 5 spiders.
Topics137,972
Posts1,079,928
Members14,882
Most Online581
Apr 3rd, 2017
lugs for aftermarket alloy wheels? #1104083
01/16/18 03:30 AM
01/16/18 03:30 AM
djacidjac  Offline OP
PA USA
This is more of a general wheel & lug question but it is for my Raider. I got some nice used alloy wheels but I'm not sure if the lug nuts I got are the best fit. The wheels are thick. I got extra long "ET" lug nuts with a 60 degree conical seat. They basically work. But I feel like they are not staying tight and they seem to budge loose too easily. So I have 2 questions (any other info is appreciated, I never looked into lug nuts before):
1. The shank(? the tubular part that extends deep into the hole on the rim) on the lug nuts reaches almost to the back of the wheel, there's about 1.5mm before they would bottom out. Is that enough room for the lugs to correctly clamp the wheels down? Should I remove some of that shank length?
2. The conical seat on the rims has some burr on it and some oxidation from sitting. What's the best way to de-burr and clean the seats? (I'm planning on getting an open-ended lug, putting it on the end of a threaded rod, cutting a groove into it's seat and carefully spinning it against the wheel's seats.)
I guess I need to clean up the wheel's seats before I can definitely say how far the shanks reach, but any info would be helpful. I did not anticipate all the shenanigans with lug nuts when I went with these wheels.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: lugs for aftermarket alloy wheels? [Re: djacidjac] #1104105
01/21/18 12:36 AM
01/21/18 12:36 AM
rxinhed  Offline
Gerber, CA *****
There are the exceptions, like Toyota and Mitsu wheels from the 90s, but not normally a shank lug nut with a seat.
Pics of the rims?
1988 Mighty Max turbo 2.6 service body
1980 Power Wagon W400
Sundry Mitsubishi Montero Gen 1 parts, Gen 1 and Gen 2 Max parts
Parts vehicles: 89 LS Montero 4-door, 2002 Sport AWD
For Sale: 1989 Power Ram 50 extended cab, #277 Montero
Re: lugs for aftermarket alloy wheels? [Re: djacidjac] #1104153
02/03/18 04:22 AM
02/03/18 04:22 AM
PA USA
Thanks for the reply, I lost my password for a bit, finally re-set it. I got it figured out. Just wanted to wrap it up in case anybody else needs to know.
The wheels were standard enough and I got the correct lugs.
1. to confirm the seats, I pressed some clay into it and compared it to a known good lug. I put some plastic wrap around the clay ball first to keep it from sticking.
2. to clean and de-burr the seats, I bought an open-ended lug nut, a bolt that matched, and a regular nut to lock the lug in place at the end. I grinded two slots in the lug face and carefully spun it in the seats using a cordless drill and some lube. turns out it was mostly discoloration, but I'm 100% sure they are clean and smooth now.
3. to check the depth, make sure they weren't bottoming out, I took them off and colored the bottom with red marker, then put them back in fully tight, then took them out again and confirmed that the marker was not disturbed.
Re: lugs for aftermarket alloy wheels? [Re: djacidjac] #1104166
02/03/18 07:12 PM
02/03/18 07:12 PM
rxinhed  Offline
Gerber, CA *****
Those rims are sexy
Re: lugs for aftermarket alloy wheels? [Re: djacidjac] #1104171
02/05/18 05:40 AM
02/05/18 05:40 AM
0778drz110  Offline
SARASOTA, FL
Are they coming loose?
I'd assume that as long as they aren't bottoming out they should be fine.
'88 Raider, 33" swampers, 2" body lift, 10K winch
Moderated by  Macka, Mudraider, off-roader, PajEvo, rxinhed
OutdoorWire Websites
Portal page for OutdoorWire Access and Landuse Central Read More
California off road recreation news and information Read More
MUIRNet News
MUIRNet News
News and information about issues affecting outdoor recreation Read More
Off road recreation and 4x4 Technical news and information Read More
TrailTalk
TrailTalk
4x4Wire TrailTalk Forums for a variety of 4x4 tech information Read More
4x4Wire Tech Section
Jeep 4x4 Tech
Jeep 4x4 Tech
Jeep Tech from JeepWire - Mods, Maintenance, Tech and more... Read More
Isuzu 4x4 Tech
Isuzu 4x4 Tech
Isuzu Tech from 4x4Wire - Mods, Maintenance, Tech and more... Read More
| 4x4Wire on FaceBook | Google+4x4Wire on Google+|
Copyright (c) 1999-2017 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Page Time: 0.009s Queries: 17 (0.003s) Memory: 1.0080 MB (Peak: 1.1045 MB) Zlib disabled. Server Time: 2019-02-21 07:36:06 UTC
