Search E-Bay for your parts:
Search Amazon for your parts:
by rascott. 12/18/18 06:21 AM
22re randomly starts then dies . . . repeatedly
by Snowtoy. 12/18/18 02:34 AM
wheels to fit 2010 jeep patriot
by lupacexi. 12/17/18 08:19 PM
Intermittent No-Start & Stalling
by chadzeilenga. 12/17/18 02:07 PM
Montero Sport to Gen I compatibility
by Bigshankhank. 12/17/18 12:54 AM
The engine build continues...
by DRTDEVL. 12/11/18 01:54 PM
Which KYB for Gen 1 V6?
by JARED. 12/11/18 01:49 AM
by lupacexi. 12/13/18 05:37 PM
Old Man Emu Lift Installation
by jimguy11. 12/11/18 01:12 AM
by DRTDEVL. 12/09/18 02:47 PM
by Bevoman. 12/08/18 08:00 PM
by JARED. 12/08/18 12:07 PM
Tire/Wheel pics
by 99Monterrible. 11/28/18 03:18 AM
Flex test after suspension mods
Clearance check!
0 registered members (), 85 guests, and 6 spiders.
Topics137,948
Posts1,079,809
Members14,849
Most Online581
Apr 3rd, 2017
O2 Sensor 1989 Raider V6 #1104219
03/01/18 07:45 AM
03/01/18 07:45 AM
L
losduarte  Offline OP
Oakland, California
Hello all. This is a tale of California smog testing intrigue. In 2017 (with zero miles after rebuilt engine) it passed smog at the same shop in Oakland, East Bay Auto Repair. 1000 miles later my Raider failed smog with the NOX high (Max: 999. Measured: 2215). There is no check engine light on the dash display. The analog multimeter test I did using the connector behind the glove compartment shows code 11 (most likely suspect: O2 sensor. Ohm test results in 2.89, which according to the manual indicates, "repair white wire for short to ground between 2-way and ECU 24 Way).
The following threads do not address my questions:
http://4x4wire.com/forums/ubbthreads.php/ubb/printthread/Board/20/main/105897/type/thread.html
http://4x4wire.com/forums/ubbthreads.php/topics/927860.html
Question 1: why does the O2 sensor (the only O2 sensor located anywhere below the engine) located just before the catalytic converter connect to a pig tail connector leading to the transfer case? I have not done anything to the vehicle since 2017 or ever. I would have thought that the O2 sensor would connect to a wire leading to the computer unit. See attached photo of the 2 wires connected to the transfer case. I will remove the O2 sensor to do the propane torch test.
[Linked Image]
[Linked Image]
Question 2: where do I get an 02 sensor that has nearly 5 feet of wire? It's damned long snaking from the right side of the vehicle to the left side where the transfer case is. I do not want to risk erroneous O2 signals. These are some candidates but do not know if they are what I should buy:
Bosch
https://www.amazon.com/Bosch-15075-Oxygen-Sensor-Fitment/dp/B000CF1VO2/ref=sr_1_17?s=automotive&ie=UTF8&qid=1519888060&vehicle=1989-72-936-575--30-8-8-3662-1746--2--64-2-0&sr=1-17&ymm=1989%3Amitsubishi%3Amontero
NGK
https://www.amazon.com/NGK-24129-Oxygen-Sensor-Packaging/dp/B001PNEBCO/ref=sr_1_14?s=automotive&ie=UTF8&qid=1519888060&vehicle=1989-72-936-575--30-8-8-3662-1746--2--64-2-0&sr=1-14&ymm=1989%3Amitsubishi%3Amontero
Thank you.
Re: O2 Sensor 1989 Raider V6 [Re: losduarte] #1104221
03/02/18 03:41 AM
03/02/18 03:41 AM
rxinhed  Offline
Gerber, CA *****
I have an 89 LS parts car that ran when parked last year. I can pull that sensor over the weekend.
Video of previous condition, already parted down bunches
Cortez the parts car
1988 Mighty Max turbo 2.6 service body
1980 Power Wagon W400
Sundry Mitsubishi Montero Gen 1 parts, Gen 1 and Gen 2 Max parts
Parts vehicles: 89 LS Montero 4-door, 2002 Sport AWD
For Sale: 1989 Power Ram 50 extended cab, #277 Montero
Moderated by  Macka, Mudraider, off-roader, PajEvo, rxinhed
OutdoorWire Websites
Portal page for OutdoorWire Access and Landuse Central Read More
California off road recreation news and information Read More
MUIRNet News
MUIRNet News
News and information about issues affecting outdoor recreation Read More
Off road recreation and 4x4 Technical news and information Read More
TrailTalk
TrailTalk
4x4Wire TrailTalk Forums for a variety of 4x4 tech information Read More
4x4Wire Tech Section
Jeep 4x4 Tech
Jeep 4x4 Tech
Jeep Tech from JeepWire - Mods, Maintenance, Tech and more... Read More
Isuzu 4x4 Tech
Isuzu 4x4 Tech
Isuzu Tech from 4x4Wire - Mods, Maintenance, Tech and more... Read More
| 4x4Wire on FaceBook | Google+4x4Wire on Google+|
Copyright (c) 1999-2017 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Page Time: 0.009s Queries: 17 (0.004s) Memory: 0.9850 MB (Peak: 1.0571 MB) Zlib disabled. Server Time: 2018-12-18 13:16:20 UTC
