Transmission Woes
by jdavis - 10/26/21 03:16 AM
OG folks chime in!
by OldColt - 10/25/21 09:48 PM
by rascott - 10/17/21 03:36 AM
Surging on acceleration.
by Trailmonkey - 10/12/21 11:34 PM
looking for donut gasket
by 87CanadianRaider - 10/12/21 02:42 AM
Troubleshooting super select 4x4 lights
by motero - 10/07/21 06:58 PM
Meetings and things
by motero - 10/07/21 05:52 PM
Transmission Woes
by 87CanadianRaider - 10/07/21 06:41 PM
Rear defroster timer removal.
by Trailmonkey - 10/05/21 05:11 PM
Montero Sport oil filter bracket
by OldColt - 09/27/21 04:16 PM
89 SWB v6 - 4 wheel Alignment??
by polar - 09/26/21 04:39 PM
1989 Montero AT to MT swap
by BrooklynOpus - 09/20/21 03:28 PM
Photos of rig
0 registered members (), 120 guests, and 4 spiders.
Topics138,244
Posts1,081,558
Members15,216
Most Online907
Dec 28th, 2019
Starter not engaging. #1106414 08/13/21 03:46 AM
T
Trailmonkey Offline OP
From time to time when I hit the key it just taps hard, solenoid shoots the gear forward nice and hard but it won't mesh teeth with the flexplate and turn over, turn the crank pully a small amount and fires right off.
I would shim it but it doesn't bolt on like a Chevy, starter gear is beveled but I haven't yet looked at the teeth on flexplate yet to see if there's anything messed up there, when it does engage it turned over nice.
New 1000 CA / 870 CCA battery that's right at 13v.
New solenoid.
Totally disassemble and cleaned the starter. And it's the gear reduction one.
Makes me think starter gear is hanging up on the flexplate ?
Anyone have this problem and know a trick or solution ?
91 (Gen1) Monty, 3.0L V6, Auto 4 Door.
Disabled Driver.
Re: Starter not engaging. [Re: Trailmonkey] #1106418 08/18/21 02:02 PM
Mudraider Offline
That has been cables and the terminals i have found. Take the cables loose, clean them, brush the not and use acstar washer, then wire brush the threads and contact point on the starter itself.
89 SWB, V-6 5SPD, OME Shocks, 16.5X37's, 2"BL, SR axle, Gen2 brakes, Lincoln w/Superwinch
Re: Starter not engaging. [Re: Trailmonkey] #1106438 08/21/21 03:57 PM
T
All connections are clean and tight. About to go over to a baddies and remove the starter and inspect things. Update later.
Disabled Driver.
Re: Starter not engaging. [Re: Trailmonkey] #1106440 08/22/21 02:41 AM
T
Teeth on flexplate have definite signs of peening on the face and a bur on the side. Starter teeth peened on the front and wore on the one side, dremeled a bevel and it starts easy as before.
Sooo. I get to tiddy up the flexplate per tooth. From under the truck, starter gear off and do a better job on it and done deal. Pain In the neck, yes, but free.
Disabled Driver.
| 4x4Wire on FaceBook |
Copyright (c) 1999-2019 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Powered by UBB.threads™ PHP Forum Software 7.7.3
(Release build 20190728)
PHP: 7.2.34 Page Time: 0.028s Queries: 16 (0.010s) Memory: 2.8376 MB (Peak: 3.1635 MB) Data Comp: Off Server Time: 2021-10-27 03:35:31 UTC
Valid HTML 5 and Valid CSS
