Transmission Woes
by jdavis - 10/26/21 03:16 AM
OG folks chime in!
by OldColt - 10/25/21 09:48 PM
by rascott - 10/17/21 03:36 AM
Surging on acceleration.
by Trailmonkey - 10/12/21 11:34 PM
looking for donut gasket
by 87CanadianRaider - 10/12/21 02:42 AM
Troubleshooting super select 4x4 lights
by motero - 10/07/21 06:58 PM
Meetings and things
by motero - 10/07/21 05:52 PM
Transmission Woes
by 87CanadianRaider - 10/07/21 06:41 PM
Rear defroster timer removal.
by Trailmonkey - 10/05/21 05:11 PM
Montero Sport oil filter bracket
by OldColt - 09/27/21 04:16 PM
89 SWB v6 - 4 wheel Alignment??
by polar - 09/26/21 04:39 PM
1989 Montero AT to MT swap
by BrooklynOpus - 09/20/21 03:28 PM
Photos of rig
0 registered members (), 120 guests, and 4 spiders.
Topics138,244
Posts1,081,558
Members15,216
Most Online907
Dec 28th, 2019
Page 2 of 2 1 2
Re: New forum ? [Re: Trailmonkey] #1106428 08/19/21 10:18 PM
M
montyhaul Offline
Need a Spot
Frank put out the word on Facebook - Bill here- I'm in Hawthorne, only marginally closer than Ocala- pretty much all activity is on Facebook- though if you hate FB or get banned we also have a group on mewe. What do you need help with Trailmonkey? BTW- my first activity here since 2019.
Signature
Re: New forum ? [Re: Trailmonkey] #1106429 08/20/21 12:14 AM
4x4Wire Offline
Thank-you for your continued support of the 4x4Wire TrailTalk Forums.
As noted, social media are the current trend setters for many things. Social media is noted for current discussion and lacking historical reference.
Hence, traditional forums sites still function as the historical repository of information.
On January 1, 2022, 4x4wire.com will celebrate 22 years as a website. The TrailTalk Forums went life a few months later. Much has changed over the past 20 plus years.
4x4Wire is still in private control, not beholding to some corporate entity.
As requested, the Mitsubishi Forums are now at the top of the list, the first forum you see when the site loads.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
President - BlueRibbon Coalition
Re: New forum ? [Re: 4x4Wire] #1106430 08/20/21 02:36 AM
T
Trailmonkey Offline OP
No problem on support here, I prefer this over the FB stuff. But they do have the numbers.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door.
Disabled Driver.
Re: New forum ? [Re: montyhaul] #1106431 08/20/21 03:02 AM
T
Thank you, starter not engaging is my need to fix right now, new battery, new solenoid, took apart and cleaned starter, all connection are good, solenoid hits hard, but seems to not mesh with the flexplate teeth and turn over, turn the crank pully a micro amount and it pops right off. I will take the starter back off and inspect the flexplate.
Then the random running bad, my ignition took a crap on me a while back, even the ecu, not run right since, replaced.. ecu, maf unit, coil, igniter, distributor. Been thinking fuel system but starting to think its timing going wacky on me, that I'm afraid would be the ecu.
It's acting like weak fuel, or bad timing, runs fine then all of a sudden it studders and boggs, more throttle just adds spitting and sputtering for a bit and instantly clears up and takes off, here lately even then it still isn't 100% .
Best I see all connections are good, . Will put timing light on it and wait for it to mess up and see if it's the timing. After that I don't see how but could be a relay ? Something I'm missing ?
Just it ran great till the burn up of parts. Last codes I got was ... crank sensor, fuel pump and o2 sensor.
O2 is from the fuel pump not working right, pump not working right from the crank sensor (distributor) not working right, but if the ecu is flawed wouldn't that do it all ? New distributor didn't change a thing.
Fuel pump is working but not sure 100% to its peak..
Got a new fuel pressure regulator I'll put on here shortly.
Could it be something in the throttle body ? Throttle position sensor ?
Disabled Driver.
Re: New forum ? [Re: 4x4Wire] #1106432 08/20/21 08:42 AM
OldColt Offline
Thank you John,
I did not expect to be listened to when I spoke. Guess I have been giving in to the they way this world is declining with little interest in maintaining history. And this site has retained it's history while so many others have failed.
Cheers, Charlie
If It ain't broke, Modify it!
87 Montero turbo Converted back in Spring1989
95 Montero SR 3.8 DOHC Only one?
93 Pajero 3 door 6G75 Mivec with paddle shifted 5 speed
Then a Gen2 SR with full coil independent suspension.
Re: New forum ? [Re: Trailmonkey] #1106455 08/29/21 06:58 PM
T
Well this place has all but died it seems, was starting to hope more long term members would come back around.
Disabled Driver.
Re: New forum ? [Re: Trailmonkey] #1106456 08/29/21 10:41 PM
OldColt Offline
I cycle through no less than eight forums twice a day and answer what I can. Of those eight one is busy on a daily basis and two have multiple postings a few times a week. It is sad to not see the elders around, I have barely even been here 15 years yet.
A couple of the elders you see over on Farcebook and a few are, well sad to say, gone.
Cheers, Charlie
Re: New forum ? [Re: Trailmonkey] #1106457 08/30/21 02:10 AM
MarkG Offline
I wander by a couple of times every week. I'll jump in to a discussion if I can offer anything useful.
Mitsu # 6 - 98 6G72 Montero Sport, Locking Rear Diff, Aisin Manual Hubs, 31x10.5
Mitsu # 7 - 02 6G74 Montero Limited
Re: New forum ? [Re: 4x4Wire] #1106490 09/27/21 09:57 PM
JAVYPRO Offline
Hello gang, I will know when I post this. LOL. I have been a 4x4wire member for gosh so many years and still live it. It is my main source for knowledge with my 2 Gen II SWB and LWB and my Gen III still when I have joined the dark side. I got me a Jeep Gladiator, nahhhh I love Jeeps too, comes in the family.LOL
Hey John I still have my 4x4wire Jean shirt, I love it.LOL
Nothing like saying hi to the gang.
Ja y
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: New forum ? [Re: Trailmonkey] #1106502 10/03/21 06:59 PM
T
If people would actually post more it would be nice.
Disabled Driver.
Page 2 of 2 1 2
| 4x4Wire on FaceBook |
Copyright (c) 1999-2019 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Powered by UBB.threads™ PHP Forum Software 7.7.3
(Release build 20190728)
PHP: 7.2.34 Page Time: 0.035s Queries: 17 (0.013s) Memory: 2.8979 MB (Peak: 3.1635 MB) Data Comp: Off Server Time: 2021-10-27 04:34:09 UTC
Valid HTML 5 and Valid CSS
