Transmission Woes
by jdavis - 10/26/21 03:16 AM
OG folks chime in!
by OldColt - 10/25/21 09:48 PM
by rascott - 10/17/21 03:36 AM
Surging on acceleration.
by Trailmonkey - 10/12/21 11:34 PM
looking for donut gasket
by 87CanadianRaider - 10/12/21 02:42 AM
Troubleshooting super select 4x4 lights
by motero - 10/07/21 06:58 PM
Meetings and things
by motero - 10/07/21 05:52 PM
Transmission Woes
by 87CanadianRaider - 10/07/21 06:41 PM
Rear defroster timer removal.
by Trailmonkey - 10/05/21 05:11 PM
Montero Sport oil filter bracket
by OldColt - 09/27/21 04:16 PM
89 SWB v6 - 4 wheel Alignment??
by polar - 09/26/21 04:39 PM
1989 Montero AT to MT swap
by BrooklynOpus - 09/20/21 03:28 PM
Photos of rig
0 registered members (), 120 guests, and 4 spiders.
Topics138,244
Posts1,081,558
Members15,216
Most Online907
Dec 28th, 2019
New LED headlight issue. #1106434 08/20/21 03:28 PM
T
Trailmonkey Offline OP
I'm having an issue, high beam works, no low beam, now I can take the high beam wire, swap it to the low beam plug and when I turn the high beam switch on, I get low beam. So I know the low works, no flickering or anything. So I tried hooking just the low beam directly to the battery (with switch on dash) and high beam back up, still no low beam..
How is it no matter what my high beam wire turns on either the low or high (depending on which I hook to) but just low won't work ? If it needs a register, wouldn't it also not work when I hook the high beam wire up ?
I've never been great at diagnosing electrical stuff, but now my mind just can't seem to deal with this. Stumps the piss out of me.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door.
Disabled Driver.
Re: New LED headlight issue. [Re: Trailmonkey] #1106437 08/21/21 03:54 PM
T
High beam wire to high beam plug, ground to ground, new low beam from battery and switch no worky till I directly ground the ground plug to the body. Low beam via my new switch works, turn light switch on via the column and high beams stay on no matter the position. But with the column switch off I can flash the high beam on/off.
It's working now but I still don't understand the deal with high beam
Damn thing is haunted I tell ya.
Disabled Driver.
Re: New LED headlight issue. [Re: Trailmonkey] #1106442 08/23/21 05:32 PM
Mudraider Offline
Mitsubishi lights operate off switching from lo/high with negative switching. Most other vehicles operate with a positive switched set up. You need an adapter harness that converts from negative switching to positive switching.
It's about $25 for a nice tidy harness adapter.
http://imgur.com/gallery/wXY7Xvg
89 SWB, V-6 5SPD, OME Shocks, 16.5X37's, 2"BL, SR axle, Gen2 brakes, Lincoln w/Superwinch
Re: New LED headlight issue. [Re: Trailmonkey] #1106445 08/24/21 04:30 PM
T
So I can't make LEDs work unless I get that kit ?
This is why a regular bulb works as it doesn't care about +/- sides, but LEDs are only one way.
Disabled Driver.
| 4x4Wire on FaceBook |
Copyright (c) 1999-2019 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
Powered by UBB.threads™ PHP Forum Software 7.7.3
(Release build 20190728)
PHP: 7.2.34 Page Time: 0.027s Queries: 16 (0.010s) Memory: 2.8379 MB (Peak: 3.1635 MB) Data Comp: Off Server Time: 2021-10-27 04:08:41 UTC
Valid HTML 5 and Valid CSS
